Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 12-13-2010, 06:18 PM   #1936
COBRARACING's Avatar
Originally Posted by Stregone View Post
Nope, its the regular 120a xerun. It should beep when it arms to show how many cells are detected right?
No there are only two reasons why your esc should beep .
1.Abnormal input voltage (and thats at start up when the esc checks the input voltage ) and when not right it will beep.
2.Abnormal throttle signal ( when signal is low or not detected )
thats all .
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 12-13-2010, 07:07 PM   #1937
Hi, any good starting point for 2wd off road rc10 on a large track with 13.5t motor? Thanks.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is online now   Reply With Quote
Old 12-13-2010, 08:05 PM   #1938
What motor are you running
Originally Posted by toptek View Post
I have readed the pdf file and understand now how the timing works.
(is this the same with a Speedpassion?)
I find only 1 thing strange. There is mentioned that a lower start RPM with a low timing punch will give you more accelaration speed.
My own findings are that you increase the motor head and that you arn't having more accelaration speed.
I drove yesterday a race and the SP driver used my speedo because he had not enough power to keep up with the other speedo's.
He used one of my speedo's and he was a lot faster.
Now I understand wy he had to gear heavier to keep up with the others on the straight. This also made that he lost a lot of infield rip.
A low start RPM with a heavy gearing makes that the motor gets hot verry fast and doesn't has that much torck.
I will try some other settings on the speedo as I see him again.
this setup I will try.
#11-8
#12-6
#13-4
#14-1
#15-1
this way the motor stays cooler by a heavier gearing.
Also do you get more torck with the motor.
Some settings look like the same as the Tekin. The difference is, is the amound of timing and that you have more options for the Turbo ramp Turbo delay and RPM settings.
I have with my Teking 3,3degrees of timing each 200rpm.
But with a heavier gearing will this be about the same.
steve_windsor is offline   Reply With Quote
Old 12-14-2010, 02:32 AM   #1939
daleburr's Avatar
Originally Posted by snabbgas View Post
Thanks!
We want to be able to run 10-15min without overheat so maybe it best to leave it at minimum.
I myself are having great results with my Ballistic and 10deg absoulte endbell but maybe i will try upping it alittle.
I tried the v3 on the "zero" setting and it was dog slow (although did run totally cold). I cranked it upto "10" and it screams nicely now (and runs at around 60deg, so not too hot).
I've verified what sosidge says (by scanning the endbell into a CAD package); there is actually 20deg of adjustment which is why it makes a huge difference.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 12-14-2010, 02:49 AM   #1940
what settings and FDR are you using for spv3 as i can not keep up with the duo motors the pass me down the straight
life is a one way street and we are not coming back
zeddy57 is offline   Reply With Quote
Old 12-14-2010, 03:36 AM   #1941
speedpassion 13,5T
timing on 10. as I set it lower, the motor has no power.
toptek is offline   Reply With Quote
Old 12-14-2010, 05:05 AM   #1942
That is strange. As i said i run my Ballistic 17.5t at -20deg from stock 30deg setting an i am up there powerwise with most of them. I to run at 60deg/C after 10-15min (72max)
I am going to try next to increase turbo delay time and add some more endbell timing and see if temprature keeps in check.
snabbgas is offline   Reply With Quote
Old 12-14-2010, 05:50 AM   #1943
Originally Posted by sosidge View Post
thanks bro but i already have that link and have when through it several time already..
i stil need more need more resources
HSP X-STR, Orca RX1 11.5T, Xerun 120A
Heqal is offline   Reply With Quote
Old 12-14-2010, 11:18 AM   #1944
what would be a good start setting using turbo software on a xerun 120a in a f1 car?
and gearing, i`m running a hobbywing 17.5 on a small carpet track
Hatebreed is offline   Reply With Quote
Old 12-14-2010, 05:45 PM   #1945
17.5T
FDR 6.0-6.5
9. boost timing = option 8
12.turbo timing = option 9
13.boost start rpm = option 1
14 turbo delay = option 5
15.timing punch = option 1
Old 12-14-2010, 06:51 PM   #1946
RevMaxx's Avatar
Send a message via MSN to RevMaxx
just a Q: what happens to HW ESCs if u accidentally plugged the battery terminals in reversed polarity order?
RevMaxx is offline   Reply With Quote
Old 12-15-2010, 12:45 AM   #1947
steliosh's Avatar
If you didnt switch it on, nothing!
If you did switch it on... buy a new one!
www.steliosh.net/rcmoto/
www.steliosh.net/rc/
KP-Designs KP10e 1/5 rc bike, Kyosho Lazer ZX-5, HPI Baja SS, Xray T1 FK05, Venom GPV1 1/8 rc bike, Anderson M5 Cross 1/5 rc bike, TT SB-5 1/5 rc bike
steliosh is offline   Reply With Quote
Old 12-15-2010, 01:03 AM   #1948
TeamWTF's Avatar
Does not matter if it is on or off result is not good particularly on the 60a/xtreme stock version
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 12-15-2010, 01:41 AM   #1949
Bishop's Avatar
Be it switched on or not, reverse connection of the battery will result in sparks, like shorting a battery directly, don't ask me how I know, though I got lucky and did not blow anything.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 12-15-2010, 03:17 AM   #1950
steliosh's Avatar
I was lucky with my old SP LPF1.1, as well as a couple of brushed ESC's. This is when I used to have all my nimh's with bullet plugs. Later on, I changed to lipos and Dean's plugs, so I eliminated this problem, really.
