Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 05-07-2010, 04:58 PM   #166
Send a message via MSN to Matt_N
Tried this new software out tonight, and WOW! I did my first heat with my Tekin RS Pro and Nosram Pure Evo, then in the second heat I put in my Xerun with a the budget GM 13.5 and there was a huge difference! The car was faster in a straight line, felt more responsive to throttle inputs and had more punch out the corners. Only downside is the motors run a bit hotter. I was geared at 7.32fdr in my Mi4, and after a 5 minute race and a few laps before, I was seeing temps of 80-90 celcius.
Matt
Matt_N is offline   Reply With Quote
Old 05-07-2010, 05:43 PM   #167
RL.2002's Avatar
Matt
Hello matt, wanna share ur esc set-up frm #1 until #15? thankz for the sharing.
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 05-07-2010, 05:58 PM   #168
Settings as follows:
Current settings:
Running Mode: forward/brake
Drag Brake: 100%
Voltage Protect: 3.2v
DRRS Punch: 9
Brake force: 100%
Initial Brake: 40%
Neutral range: 9
Boost timing:8
Over-heat protection: enabled
Turbo: Option 7 (6)
Boost start RPM: 3000rpm
Turbo Delay: 0.4seconds
Timing Punch: Option 2 (-1)
Mat
Old 05-07-2010, 06:43 PM   #169
Send a message via MSN to hobbywing Send a message via Skype™ to hobbywing
Originally Posted by Joel Lagace View Post
One thing i noticed using the LCD was that making on the fly changes requires u to select OK for each of the 15 parameters. I was changing a bunch of things and then selecting OK only to find out only one would save. You actually have to hit save for every single setting. i did not think this was the case with the old LED box.. Anyway for any of you guys like me that just got the LCD double check your settings are staying...
Thanks Joel !
The LCD program box does need you to press "OK" button for each programmable item. It works in a different way from LED program card. So please double check the settings.
hobbywing is offline   Reply With Quote
Old 05-07-2010, 07:22 PM   #170
Current settings:
Drag Brake: 100%
DRRS Punch: 9
Brake force: 100%
Initial Brake: 40%
Neutral range: 9
Boost timing:8
Turbo: Option 7 (6)
Mat
Drag brake at 100%? I think if you run closer to 0, your temps should go down more.
redbones is offline   Reply With Quote
Old 05-07-2010, 10:02 PM   #171
Matt
Try the suggested settings for a 13.5. They are pretty good and will keep the temps nice and low.
Mike
ixlr8nz is offline   Reply With Quote
Old 05-07-2010, 10:42 PM   #172
Born2Run's Avatar
Current settings:
Drag Brake: 100%
DRRS Punch: 9
Brake force: 100%
Initial Brake: 40%
Neutral range: 9
Boost timing:8
Turbo: Option 7 (6)
Mat
Drag brake 100% with brace force on 100%? Are you sure about this?
Whatever
Born2Run is offline   Reply With Quote
Old 05-07-2010, 11:03 PM   #173
snowman_evil's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to snowman_evil
Is the latest hobbywing and Speed passion software the same or different?
Which is better, Ill be racing tonight with my Xerun 120amp esc and 17.5 tekin motor. Ill keep you guys posted on my thoughts
DEX410V3 - Tekin - Spektrum - Panther
GCRC Raceway - "Lightning"
snowman_evil is offline   Reply With Quote
Old 05-08-2010, 03:25 AM   #174
gixer's Avatar
Ran this last night with the recommended settings for the 13.5T motor (running the XeRun 13.5T).
#9 8
#12 7
#13 6000rpm
#14 0.4sec
#15 -1
Measured 75c motor temp after 5 mins of driving.
This seemed bloody hot to me so i tried a few different settings.
#9 6
#12 5
#13 9000rpm
#14 0.5sec
#15 -2
Noticeably slower but the motor ran a fair bit cooler at 52c.
Couple of questions please.
1/ What sort of motor temps your guys seeing?
2/ What sort of temps do you think is acceptable?
I want to have Mode 3 as stock just in case i get any problems on the track, could someone please confirm these are the stock settings?
#9 1 (0)
#12 1 (off)
#13 9 (15000rpm)
#14 9 (0.8s)
#15 7 (1000)
Lastly could some one please advise which way to go to run the motor hotter or cooler.
e.g.
#9 1 cooler - 9 hotter
#12 1 cooler - 9 hotter
#13 9 hotter - 1 cooler
#14 9 hotter - 1 cooler
#15 9 hotter - 1 cooler
*Edit
I'm running a 6.97 final gear ratio
Cheers
Mark
HB Cyclone (WCE Exotek) x 2, Pro3 (Penguin chassis), Pro4, M-04M (Eunos Roadster)
Losi MRC, Axial XR-10
ERevo Erbe, HPI Firestorm (Nitro), Blitz,
gixer is offline   Reply With Quote
Old 05-08-2010, 07:43 AM   #175
I know drag brake will increase temperature, but I've tried driving without and things dont seem right, the car just feels 'weird' to me, but with the drag brake turned up, things just feel right to me. Might just reduce it a little bit each week, get used to lower amounts of drag brake in stages, rather than going from 100% to 30%.
Matt
Old 05-08-2010, 09:23 AM   #176
steliosh's Avatar
Mark,
I think Hobbywing wrote it somewhere in here, and I actually wrote it as notes on my printed pdf, just to have it with me... So...
Item 9: Actual timing: 0* = cooler, 21* = hotter
Item 13: Motor Speed (RPM): 3000 = hotter, 15000 = cooler
Item 15: Timing Punch (RPM/Degree): 200 = hotter, 1000 = cooler.
Edit: I have next to coolest settings for my bike and the motor runs at around 55-65*C after 7 minutes...
But... the bike, as noted earlier has different loads, gearing, weight etc than touring cars...
However, going towards the cooler settings worked for me...
www.steliosh.net/rcmoto/
www.steliosh.net/rc/
KP-Designs KP10e 1/5 rc bike, Kyosho Lazer ZX-5, HPI Baja SS, Xray T1 FK05, Venom GPV1 1/8 rc bike, Anderson M5 Cross 1/5 rc bike, TT SB-5 1/5 rc bike
steliosh is offline   Reply With Quote
Old 05-08-2010, 09:36 AM   #177
gixer's Avatar
Thanks mate,
Just off for a practice session now so will see how i get on.
Old 05-08-2010, 10:10 AM   #178
Born2Run's Avatar
Matt
If it was a Mamba Max speedo i could understand the 30% drag brake.But with the HW on FDR 7.32 with a 13.5T even 30% drag brake is to much.
Whatever
Old 05-08-2010, 03:50 PM   #179
Ive also found the HW has alot of drag brake. Even with my drag brake on 0% with a 17.5 tekin its almost the equivalent of some other brand ESC's set on 15%. I kept my drag brake at 0% which was perfect for my track and kept the motor a bit cooler because of this aswell
Old 05-08-2010, 04:03 PM   #180
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
I ran the new turbo set up in my xerun 60 with a HW 13.5 in my TQ Racing SX10 2w this weekend for the first time. I used the recommended setting for a 13.5 and although I changed my gearing slight, I went a bit higher because its off road, it felt much quicker all around. I kind of compare it to when comm drops came out for brushed motors, but this was much more consistent.
I didn't notice any hearing issues, but this was off road so, it's a little different.
Nice improvement over stock set up, and I liked the stock set up.
Hobby Authority Distributions Marketing Director
** www.hobbyauthority-dist.com / www.maclan-racing.com ***
Sponsored By: Maclan Racing, XRay/RC America, J Concepts, Xpert R/C, G Force USA, X Factory, Boom Graphics, Hobby Authority
nikos2002 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
