Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 11-29-2010, 05:49 PM   #1771
csracing's Avatar
Trader Rating: 22 (100%+)
Originally Posted by warnos View Post
Just an idea but do u have the reverse strength at 100%? not sure why but it helped on my brakes even though u are running forward only.
What have you got the brakes set at?? if you but the brakes on 100% with no initial brakes do u have the same issue? thats what i have and it has too much brakes.. just change the EPA-b to adjust it..
If u wanna run initial brakes though I am no help...
Good luck
Reverse strength is 100%. I'm sitting here playing with every brake setting I can find with no luck. If I sit at neutral throttle for approximately 1 second, then go to brakes, I get full brakes. But if I don't pause at neutral I only get whatever the initial brake setting is (in this case, 40%). Just freewheeling it's very noticeable and is even more noticeable on the track. Quite annoying. I hadn't noticed it on our last track layout as there really weren't any braking sections. The new layout has a couple areas that require brakes and I'm finding that the ESC isn't working to my satisfaction at all...
csracing is offline   Reply With Quote
Old 11-29-2010, 07:16 PM   #1772
JKL1031's Avatar
Reverse setting. not brake setting.
China Lipos
China Speedos
China Chargers
You aint messin wit my dougie..
JKL1031 is offline   Reply With Quote
Old 11-29-2010, 07:18 PM   #1773
csracing's Avatar
Reverse setting at 100%, that's what I meant. I'll update my answer above.
Old 11-29-2010, 08:45 PM   #1774
COBRARACING's Avatar
Originally Posted by csracing View Post
I've tried running as much as 20% drag brake but it makes no difference. Power to full brake is much less brake force than power to neutral, then to full brake. Doesn't make any sense..
Can you please tell me what radio brand and what spec radio you are using .?
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 11-30-2010, 01:21 AM   #1775
chinaman's Avatar
Default Xtreme Stock ESC
Was racing last weekend. The car kept stuttering and was alright for awhile then it just slowed and kept the slow speed. It was like as though the voltage cut-off was coming in.
I was using a 4000 mAh 30C Lipo and apparently it did not like the freezing temp of 0 degC. Changed the battery to a 5000 mAh at 40C and it was fine.
... wyrd bi ful rd ...
chinaman is offline   Reply With Quote
Old 11-30-2010, 02:40 AM   #1776
I can see from your signature that you are using a 3pm futaba radio is that correct ?
Please send me an email at [email protected] and i will email you a patch file that will sort out your issue with the brakes ok.Ill explain to you how to install through email
regards Angelo
Old 11-30-2010, 02:59 AM   #1777
what is the maximum and safe operating temperature for the esc and motor??
or how is it for me to find it out?
HSP X-STR, Orca RX1 11.5T, Xerun 120A
Heqal is offline   Reply With Quote
Old 12-01-2010, 02:57 AM   #1778
95 degrees is our cut off
Old 12-01-2010, 05:15 AM   #1779
irgo's Avatar
Default Esc Firmware with Data Log
Well The answer is Data Log Esc Firmware,
sure is the Firmware released ?
RPM Log, Temp Log, Voltage Log, Amp, Log
and maybe Speed Log.
Quark Force
irgo is offline   Reply With Quote
Old 12-01-2010, 05:19 AM   #1780
it would be nice, but, a software is only as good as the hardware.
We're not sure what the 120A's technical limits are.
Or....120A V3.0 is coming out!??!?!?!?!?!
cheapskate.brok is offline   Reply With Quote
Old 12-01-2010, 08:30 AM   #1781
chinaman's Avatar
Originally Posted by cheapskate.brok View Post
Or .... 120A V3.0 is coming out!??!?!?!?!?!
i thought the 2.1 version just came out???
Old 12-01-2010, 01:55 PM   #1782
If you have a charger that can test for internal resistance of your battery pack you will see its on its way out the resistance would have increased by a significant amount.
Old 12-01-2010, 02:00 PM   #1783
It was discussed yesterday about a data logger with the software especially temp and rpm which will benefit hobbywing and the end user .Hobbywings benefit will be that the log will be none deletable so when there is warranty issues we can download the info when the esc is sent in for warranty or repair and we will know excatly what happened to it .For the consumer it will be a great way not only to protect your esc's but improve on your settings and setups .
Old 12-01-2010, 09:52 PM   #1784
RevMaxx's Avatar
Send a message via MSN to RevMaxx
while this will be very beneficial, it may shoot up cost which may not be very attractive to us budget hobbiest.
though it would also be nice to have these as options should the need arise...
RevMaxx is offline   Reply With Quote
Old 12-01-2010, 11:04 PM   #1785
Default HW Xtreme firmware
Hi i cannot find firmware for Xtreme stock on HW wed site?
Andy 540 is offline   Reply With Quote
