Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 11-05-2010, 01:09 PM   #1606
Default setup HW X12 10.5
Originally Posted by Chaz955i View Post
Much appreciated
Hello I thank you for this setup, Sunday I had the same with a 10.5 on my lrp X12 R5.1 my car was working fine, (turbo, tirming, rpm.) Hand against this setup does not work with a speed 10.5 V3 passion.
david M is offline   Reply With Quote
Old 11-05-2010, 03:34 PM   #1607
M7H
M7H's Avatar
Originally Posted by TeamWTF View Post
Also, there is no advantage in using the 120a in stock racing over the 60a, otherwise there would be no Xtreme stock esc....
The new 120a 1S has the advantage that you don't need a booster or seperate receiver battery for 1S Lipo racing in 1/12 scale.....
Serpent
M7H is offline   Reply With Quote
Old 11-06-2010, 05:20 AM   #1608
jake95's Avatar
Trader Rating: 27 (100%+)
i need a set up for 4.5 with 120amp 2.1 esc and fdr for it
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 11-06-2010, 11:33 AM   #1609
Hi ive just got my xtreme stock ESC. ive got a competition in the morning.
I'm running 10.5 speed passsion v3 motor and have set the gear ratio at 6.81 to start.
What is the latest stock software ? I have bought a 2 in 1 pro box.
How do i download latest software etc if i need it ?
Any advice from you experianced users would be great
Finch wxm is offline   Reply With Quote
Old 11-06-2010, 01:17 PM   #1610
TeamWTF's Avatar
The current software should be loaded on it from factory
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 11-06-2010, 03:25 PM   #1611
blade072's Avatar
Trader Rating: 98 (100%+)
pm sent....forgot to say i use 518Stock firmware.....
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 11-07-2010, 12:39 AM   #1612
Hello go to page 22 for the answer
Old 11-07-2010, 01:10 AM   #1613
steliosh's Avatar
I am running my 1/5 motorcycle with a Xerun 60A powering an LRP X12 13.5T. I have used this motor since August, when I got it new at the RC Bike Worlds. It has ran maybe 100 batteries through it. Two weeks ago, I tweaked the settings to "almost max", since the weather was rather cold and the motor, running with a cooling fin, but not a fan, never went over 75 deg. C. the FDR, finally was 6.94:1, which was the one used at the Worlds, successfully.
The settings I used were:
No. 9 at 7 (18*)
No.12 at 8 (7*)
No.13 at 4 (7500)
No.14 at 5 (0.4s)
No.15 at 2 (300rpm)
Yesterday was a rather warm day, at 21-24*C, and suddenly the bike started losing power. I checked at a huge car park, sent it away, full throttle, it seemed like half throttle, I insisted, then suddenly a cut of power, and then a burst of full power! Unfortunately the ESC is buried deep into the fairing and I could not check for blinking leds...
I thought to myself, it's the sensor cable. I changed that, it went a bit better, but after 2-3 minutes it started doing it again. I monitored the motor temp at 65C, during all this testing...
I toned down the settings to:
9 at 4
12 at 5
13 at 5
14 at 5
15 at 5
and it did it again, but at a lesser degree...
Maybe the motor is near its useful life?! It has never overtemped, meaning never over 65-75 deg C...
Any ideas?!
www.steliosh.net/rcmoto/
www.steliosh.net/rc/
KP-Designs KP10e 1/5 rc bike, Kyosho Lazer ZX-5, HPI Baja SS, Xray T1 FK05, Venom GPV1 1/8 rc bike, Anderson M5 Cross 1/5 rc bike, TT SB-5 1/5 rc bike
steliosh is offline   Reply With Quote
Old 11-07-2010, 09:47 AM   #1614
steliosh's Avatar
Well... since it was election day today and after doing what needed to be done in that department, I took the "old" Nosram (X11-equivalent) 13.5T and installed it on the bike.
I ran it again and all the symptoms were gone. I even tried the "old" sensor cable, just to make sure...
Everything is working lovely!
So, it seems the LRP X12 has had its life! RIP, then, only it was a very short life, indeed!!!
Old 11-07-2010, 10:50 AM   #1615
Tried my car today for the first run with the xtreme stock, had no top end speed and seemed really slow !
I'm running it with a speed passion version 3 . Didnt have chance to play and had to take it out !
any ideas why it seemed so slow. I had 116 with a 24 pinion, im ruuning the schumacher MI4LP.
its a brand new motor, sommethink must be really wrong with my setting !
Old 11-07-2010, 12:22 PM   #1616
Default More questions
OK I have a questions here,do the supercharged software works only with sensored motors or can be used with sensorless too?
raypa is offline   Reply With Quote
Old 11-07-2010, 12:56 PM   #1617
Trader Rating: 17 (100%+)
Default FDR
Hi guys, just a quick query,
running a Schumacher MI4 (1.8:1) in 21.5 with extreme stock speedy, on a medium size track.The track has a good mixture of slow and fast sections. current FDR is 4.64, rollout is 42.69. this is being acheived with an 85t spur and 33t pinion.
my question is this, is it better to use a smaller spur/ pinion to get the same rollout/ FDR or stay the way I am. would need to order smaller spurs if this was the case
thanks in advance
Lee
Team Awesomatix
R1 Wurks
RC Maker.com
Southern Tasmania Model Car Club
lethallee69 is offline   Reply With Quote
Old 11-07-2010, 02:39 PM   #1618
RAn my xtreme stock for the first tome today and its awesome. After a 5min race my motor temp is 105*f. my question is is this a decent temp to be hitting. I currently have a FDR ratio 0f 7.65, Car is a Schumacher mi4 Using a norsam storm evo 10.5 I will post my setting up later
scytherat is offline   Reply With Quote
Old 11-08-2010, 12:27 AM   #1619
synrgy's Avatar
Guys where can i get the latest firmware for the xerun 60a v2,0 esc & also the software for the usb programming box, software link on HW site is dead..
synrgy is offline   Reply With Quote
Old 11-08-2010, 01:19 AM   #1620
jake95's Avatar
anyone
XRAY✯NOSRAM✯SANWA
