Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 11-04-2010, 05:56 AM   #1591
Chaz955i's Avatar
Originally Posted by Benzaah View Post
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
For those too lazy to look. This is good advice.
Thanks, that explanation of the settings is really helpful.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 11-04-2010, 06:47 AM   #1592
SO by your wealth of knowledge FDR is not an important factor?? And the punch setting has no effect on anything?? really your better off not giving any advice if you are going to give bad advice.
If your new to this speedy then search this thread for early posts by Razzor. he explains this speedy very well. Saying Mikky32 and the tekin thread is a good place to start when he has been banned for just dribbling soooo much shit is wrong. Are you the new handle for Mikky? can we geta mod to do a isp check
When i started with this speedy i had the following settings suggested.
Think you`re last line says it all, think Mikky32 was one off the pioneers of this speedo type, at least in my country.
In my opinion it is useless to give numbers if you never saw the track where somebody is driving. It`s better to let somebody understand the basics...
rbakker is offline   Reply With Quote
Old 11-04-2010, 08:32 AM   #1593
M7H
M7H's Avatar
Originally Posted by Chaz955i View Post
Much appreciated
Don't forget that it's quiet an agressive setting....
Serpent
M7H is offline   Reply With Quote
Old 11-04-2010, 08:33 AM   #1594
Born2Run's Avatar
Originally Posted by COBRARACING View Post
As for the esc going to sensoreless mode and that causing it to slow down doesnt seem right as there is no such thing i have heard it many times from people on this site but believe doesnt make sence .
Angelo are you trying to say that when the esc goes to sensorless doesn't seems right to slow down or that the esc doesn't turn to sensorless?
Whatever
Born2Run is offline   Reply With Quote
Old 11-04-2010, 04:46 PM   #1595
"MrQuiick"'s Avatar
I have read some of the threads and have not found anything on the top of my question, but forgive me if I missed it. My question is are there any proformance gains in the Xerun 60A and the 120A while running the ESC(s) in a 1/10 sadan with a 2s lipo with 45c? would I be increasing proformance by upgrading to the 120A?
Dan "MrQuiick" Dix
Xray T3-17.5 Boosted (Mazda 6), Xray T2 009-21.5 super GT (2008 MB AMG DTM C-Class)
"MrQuiick" is offline   Reply With Quote
Old 11-04-2010, 04:49 PM   #1596
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
not necessary really
OVA is offline   Reply With Quote
Old 11-04-2010, 06:26 PM   #1597
TeamWTF's Avatar
The speed control can go in to sensorless mode if settings are too aggressive. This will cause the car to run much slower, as the timing functions will not be working (in sensorless mode)
For example, a 17.5 with timing might be geared around 5.5 - 6.0. A non timed 17.5 would be geared under 4.0... so in sensorless mode, without timing, it will obviously be very slow.
I have had this happen with a 10.5 (duo 2) once or twice... too much motor timing and speedo timing. I lowered the motor timing (2-3 geaduations from the zero mark, was previously at around 5) and lowered the gear ratio (7.5 to 7.0). This solved the problem. I let the motor do more work instead of the timing...
Also, there is no advantage in using the 120a in stock racing over the 60a, otherwise there would be no Xtreme stock esc....
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 11-04-2010, 06:30 PM   #1598
Old 11-04-2010, 09:09 PM   #1599
desert truck 1's Avatar
Default BOOST OFF FOR SANCTIONED EVENTS
Originally Posted by AGNO View Post
Yes! Is the 508 NO TIMING.
But does that give a flashing light or what indication that the boost mode ahs been dissabled????
MINDS ARE LIKE PARACHUTES... THEY WORK BEST WHEN OPEN
http://www.chargersrc.com/
Losi XXXT-CR, Losi XXX-CR, LOSIXXX4G+,Losi Desert Truck,Tamiya F103, VENOMGPV-1 1/8 bike. Spektrum DX3R/DX6, Planes out the wazzoo, Big Choppers, FPV Quads, lots of guns & not enough weekends!!
desert truck 1 is offline   Reply With Quote
Old 11-05-2010, 01:27 AM   #1600
AGNO's Avatar
Yes, with 508NO TIMING the red light flashing in the neutral.
The 508 NO TIMING is already approved ROAR because used in Speedpassion ESC, I hope that soon also approve the Hobbywing ESC.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 11-05-2010, 01:31 AM   #1601
what about a lower internal resistance (120A's 0.003ohm vs. 60A"s 0.006ohm)?
cheapskate.brok is offline   Reply With Quote
Old 11-05-2010, 05:02 AM   #1602
M7H
M7H's Avatar
Much appreciated
Checked once more, Setting 12 is not 9 but 8.... (not a huge difference)
Serpent
Old 11-05-2010, 05:42 AM   #1603
Anyone advise me on how to set up the xtreme stock ?
I'm going to do it tonight, i have also bought the pro programme box.
I'm running 10.5 stock do i need to download software from somewhere ?
could someone give me a brief guide on what i need to do etc ?
thanks
finch is offline   Reply With Quote
Old 11-05-2010, 06:06 AM   #1604
M7H
M7H's Avatar
In the manual for the Xerun 120a 1s, on page 2, the settings table.
http://www.hobbywing.com/upload/manual/HW-09-1s.pdf
Can anyone tell me if the values mentioned there are based on the 528MOD or 518STOCK software?
If they are based on the MOD software, what are the values for the STOCK software then?
Serpent
Old 11-05-2010, 12:34 PM   #1605
TeamWTF's Avatar
Its 0.0006 - The same as the Xtreme stock - and again if it was an issue there would be no xtreme stock speed control. I ran my 120a and Xtreme stock back to back and the only thing i noticed was the 120a seemed to have a little less brake.
If the 60a is all you can budget for then get it. It is a great speed control. Obviously if you can afford it go the 120a for no reason other then lower turn limit....
Either way you will be competitive
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
