Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 05-05-2010, 07:11 AM   #136
Send a message via MSN to hobbywing Send a message via Skype™ to hobbywing
Originally Posted by Joel Lagace View Post
HOBBYWING: one thing that needs correction is the PDF file. The terminology used does not match the last 5 settings on the ESC LCD read out... You have to remember what setting your own because the names of the settings are not identical on the PDF as they are on the software and LCD
Thanks very much, Joel
The information will be sent to R&D department and our engineers will check this.
hobbywing is offline   Reply With Quote
Old 05-05-2010, 07:18 AM   #137
IF while your ESC is connected to the PC you label 1,2,3 to what ever name you want and then load to ESC... Anytime after that that you connect your LCD to just the ESC you will see those 3 custom names you chose.
for instance my:
Buggy ESC has 1-Buggy 2-Buggy slick track 3 F'ing crazy
SC10 ESC has 1-SC10 2-SC10 slick track 3-F'ing crazy
Understood. Thanks.
Just use the LCD card to change the setting as per profile 1/2/3, But the firmware in ESC is still not changed at V1.6 beta.
e.g. the ESC firmware is mod (without supercharged), all your setting in profile1/2/3 are corresponded to this firmware (no turbo setting).
What i need is to change the firmware too, via LCD card only condition.
IE: profile 1 - with turbo firmware & turbo setting for stock race (13.5T)
profile 2 - mod firmware (no turbo) & setting for modify race (4.5T...)
mos-leung is offline   Reply With Quote
Old 05-05-2010, 07:37 AM   #138
Joel Lagace's Avatar
ya you can only run one firmware at at time. maybe in the future they can have a firmware where you can shut off the un needed supercharged turbo functions for modified motor use. like the last 5 settings should be able to choose N/A to turn them off...
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 05-05-2010, 08:06 AM   #139
razzor's Avatar
Originally Posted by mos-leung View Post
Understood. Thanks.
Dont think the program card has the capability and storage for keeping and installing different firmwares.
Best is to change to firmware 205 for mod or the alternative 323.
323 does work fairly well on smaller tracks with stock motors.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 05-05-2010, 10:34 AM   #140
steliosh's Avatar
Last time I reported I had some problems with my 3-minute runs which turned to sensorless...
OK, as many suggested, it was the sensor cable's fault, somehow. I installed a new one and the bike rocks again (and rolls, as well, but we will come to that in a minute!).
So, I started once again with the suggested settings of HW for the 13.5T motor, from their PDF:
9=8
12=7
13=3
14=5
15=2
I didn't even have a thermal issue, even though I ran the bike at 16.00 in the afternoon with ambient temp of 28*C. However, the top speed was not there, or it would appear at the very end of the longest straight... and the acceleration out of slower corners was quite mild, not that this is a bad thing on a leaned over motorcycle!
So, I went to Cobraracing's settings:
9=8
12=8
13=4
14=5
15=4
Almost the same things, and the motor is still very hot but not thermalling after 7 minutes continuous running, a bit better acceleration out of slower corners. All observations by eye, really, since I do not have lap counting systems, or radar gun to check speeds... It's how the bike feels...
So, I took HW's advice and went for settings to cool down the motor a bit. Incidentally I happened on a good setting:
9=5
12=8
13=7
14=5
15=6
Now, I have wheelies on demand, which spectacular may be, but they hurt lap times (!!), decent top speed attained at around the 2/3's of the main straight and very good acceleration out of corners, without unwanted wheelies or bad headshakes or running sideways, all of which usually end up in a tumble!!!!!! (the rolling I was talking about earlier!)
So far so good, then, and I will continue my testing in the next few days!
Remember, I'm talking about a 1/5 motorcycle, Xerun 60A (on 422 SW) and Nosram 13.5T.
My gearing for the moment is longish at 56/22 spur pinion and 30/11 chain sprockets, which nets an overall 6.94 FDR. I will have to consult the British guys who are a lot more experienced on gearing for the bikes, even though I feel that a bit of shortening the FDR would do me good!!!
Can someone produce a new setup sheet for the new settings and as someone else suggested earlier, it'd be very helpful to re-organize the words in the pdf and LCD to be the same, so they are not confusing...
www.steliosh.net/rcmoto/
www.steliosh.net/rc/
KP-Designs KP10e 1/5 rc bike, Kyosho Lazer ZX-5, HPI Baja SS, Xray T1 FK05, Venom GPV1 1/8 rc bike, Anderson M5 Cross 1/5 rc bike, TT SB-5 1/5 rc bike
steliosh is offline   Reply With Quote
Old 05-05-2010, 12:13 PM   #141
gixer's Avatar
Stelios where do you practice mate?
You attending the Yokomo drift championship on Sunday at Aspropyrgos?
Cheers
Mark
HB Cyclone (WCE Exotek) x 2, Pro3 (Penguin chassis), Pro4, M-04M (Eunos Roadster)
Losi MRC, Axial XR-10
ERevo Erbe, HPI Firestorm (Nitro), Blitz,
gixer is offline   Reply With Quote
Old 05-05-2010, 02:14 PM   #142
megasaxon's Avatar
Trader Rating: 25 (88%+)
Send a message via AIM to megasaxon Send a message via Yahoo to megasaxon
so this new software will work with all of these speed controls?
http://cgi.ebay.com/XERUN-60A-SD-V2-...item58877691ad
http://cgi.ebay.com/Hobbywing-XERUN-...item1e5bbe0334
http://cgi.ebay.com/XERUN-120A-SD-V2...item5887247fbc
and
http://cgi.ebay.com/Hobbywing-XERUN-...item4a9fb4efa7
is that correct?
Team Associated RC10GT
Team Associated RC10GT2
megasaxon is offline   Reply With Quote
Old 05-05-2010, 03:49 PM   #143
steliosh's Avatar
Cheers
Mark
I'm at the north, so I usually go to a huge parking lot near Makro, at Anthoussa... And whenever I can, to FRT track. I don't race Yokomo Drift, though... Say hello to Renos, then!
(from Frenos! he will understand!)
I race RCGT, MMC and ELME, electric touring and buggy.
Preparing for the rc bike world champs, with the bike too!!!
Call me nuts, I AM!
Old 05-05-2010, 03:55 PM   #144
hectickurt's Avatar
Has anyone run this software in a Wgt car 1s lipo 10.5 brushless? If so how did you find it. Im looking for a new speedo for my WGT and this sounds promising
non illegitimatis carborundum!
Xray T3R, Hobbywing electronics. Yeah baby!
Rob(not Lee) Streeter
hectickurt is offline   Reply With Quote
Old 05-05-2010, 04:30 PM   #145
gixer's Avatar
Call me nuts, I AM!
Nice one.
We'll have to meet up for a drifting session one time, wouldn't mind a good look at KP bike.
Old 05-05-2010, 10:59 PM   #146
snowman_evil's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to snowman_evil
Hey guys is SC RPM the same as start or end RPM??? For SC RPM Delay, SC Full throttle delay etc...
DEX410V3 - Tekin - Spektrum - Panther
GCRC Raceway - "Lightning"
snowman_evil is offline   Reply With Quote
Old 05-05-2010, 11:05 PM   #147
razzor's Avatar
Read through this document to understand how the Supercharge works.
http://www.hobbywing.com/upload/manu...-Hobbywing.pdf
Casterracing ZX1.5R
Old 05-05-2010, 11:06 PM   #148
irgo's Avatar
actually you can turn off the super charge, and run like stock software
and also like a software Mod,
basically Super charge Software is the base of all previous software firmware,
that is now served freely to configure. Because as previous improvement was
designed per step :
1. Mod Firmware - Safeties
2. Stock Firmware - Tricky
3. Supercharge Stock Firmware - Highly dangerous.
as Supercharge firmware was the last Improvement you will see it can be turned off :
select :
Item 12 - Value 1 - to turned off
Item 13 - Value 9
Item 14 - Value 9
Item 15 - Value 9
with above settings it will act as Stock Firmware or Mod Firmware.
Quark Force
irgo is offline   Reply With Quote
Old 05-05-2010, 11:15 PM   #149
Trader Rating: 8 (90%+)
What software is on this speedo when bought new?
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris Totcky@facebook.com
Tha Skinny is offline   Reply With Quote
Old 05-06-2010, 12:14 AM   #150
Are the software feature meant to be on the Advanced menu of the ESC settings on a PC? On the 1.61 PC software I hook up the ESC and go into advanced settings and it only has Initial Brake force, Neutral Range, Boost timing, Over heat protection, Turbo Level, Boost Start RPM, Turbo Open Delay and timing Punch. How do I get the Supercharged Features???
Is the supercharged software even good? From what Ive heard its very risky with motor temps etc....
