Lipo battery for losi starter box help
I have the RTR losi starter box and bought 1 of the Team Losi 4S Li-Poly Starter Box Battery Pack 20C (14.8V/2200mAh). I see that the start box has 2 plugs to plug 2 batteries. My question is should i use one of the losi lipo battery or should i used 2, on the starter box? Im not sure if the 2200mah is good enough to turn on my engine.
cut the factory plugs off the starter box and put whatever is on your lipo on the starter box. I put a turnigy 2600mah 4s lipo and low voltage alarm on mine with traxxas plugs and its got tons of power and its way lighter
I personally bought the newest losi starter box and went with the losi starter box lipo. I put the thing together this weekend. Both the lipo and the starter box had tamiya plugs on them. The starter box has two tamiya plugs coming out of it. One of them you use to plug the lipo into and with the starter box came with a "dummy" tamiya to put into the other spot. Mine works fine. Hope this helped
