Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-06-2010, 12:31 PM   #1
Trader Rating: 58 (100%+)
Default Bad Brushless motor ?
How do know or check to see if a brushless motor has or is going bad? Thanks
cul8tr is offline   Reply With Quote
Old 04-06-2010, 01:19 PM   #2
I think the only way would be to hook it up to a brushless esc and see if it works. It's not like a brushed motor where you could just apply voltage to get it to spin.
Why do you think it is bad?
SC10Fan is offline   Reply With Quote
Old 04-06-2010, 01:44 PM   #3
Trader Rating: 21 (100%+)
You can check continuity across the motor leads, any probs with windings would show up there. If it won't run when iots hooked up, check batt voltage and then check voltage at esc motor leads - they should be real close. If the voltage is diff, may be teh esc, if voltage is almost the same, its prob motor.
If its a prob with the rotor, short of one coming apart and not wanting to turn, don't know any way to check that. If motor has seen enough high temps, it can demagnetize and just stops working.
Duster_360 is offline   Reply With Quote
Old 04-06-2010, 02:46 PM   #4
It got a high temp 1 time over 220 deg. Ever since then a 5 to 8 min. run it will just about burn you to touch it, esc and motor. Shuts down. I've played with different gear ratios, no change. I've tried 2 different esc's also, no change. The only thing that I haven't changed is the motor. I'll try that next. Thanks
Old 04-08-2010, 07:49 AM   #5
Default Another way to test your BL motor
I'm not sure how much you know about these little beasties....but they are built in theory similar to a motorcycle alternator....in fact.....nearly exactly. If you're running cars....you are probably using an in-runner type. Most of the aircraft guys use out-runners....where the moving piece of the motor is a bunch of strong magnets glued to the inside of a bell housing surrounding the field. The whole system is a lot like a three-phase alternator. Without pulses from the ESC in the correct sequence....the motor won't run. I haven't had a motor go defective yet....but I have had an ESC lose a phase. The motor just sits there & gets hot....grunts....but doesn't turn.
Now the test.... Remove your motor and chuck the shaft in a drill....or better....a drill press. Secure the non-moving part of the motor so that it won't turn. Spin it up to make sure all is secure....you certainly don't want to see your motor go flying across your shop. With the motor shaft spinning at as high a speed you can muster from your drill...get out your volt meter....set it to AC vots and measure the voltage between all leads. They should all be about the same. If not..... one of your windings has shorted or maybe open. If your motor gets warm during this test.....it's defective.
Flash
Flash1940 is offline   Reply With Quote
Old 04-08-2010, 01:38 PM   #6
Hey thanks for the quick test of the motor. I'll try it in a bit. Thanks
Old 08-11-2016, 06:26 AM   #7
constabluntss's Avatar
Flash's way is genius. If you can, do it that way. Any significant difference in voltage or amps across any 2 of the leads means spare parts bin.
constabluntss is offline   Reply With Quote
Old 08-11-2016, 08:06 AM   #8
Geezatec's Avatar
Good question! It being brushless only thing is continuity check. I don't how to ck sensor ck, but Tekins has a on-board ck . The worst thing for brushless is heat. the rotor is a permanent magnet and they do seperate. If really deep into it maintain the bearing and bushings.
Geezatec is offline   Reply With Quote
Old 08-11-2016, 08:11 AM   #9
Trader Rating: 215 (100%+)
But...that test was done 6 years ago! (check post date)
Andy Koback is offline   Reply With Quote
F/S Novak GTB esc #1710 and 13.5T Brushless motor Ebola888 R/C Items: For Sale/Trade 40 09-18-2009 09:53 PM
Spy Shot: New Brush to Brushless Motor dyno Converter Module Veteq Electric On-Road 38 12-29-2008 10:09 AM
Novak Super Sport Brushless Motor System glide 1 Electric On-Road 437 03-26-2004 11:03 PM
Brushless Motor Discussion Alvin Singapore R/C Racers 113 10-22-2002 03:47 AM
