Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 03-27-2010, 06:15 PM   #1
breez1090's Avatar
Default Spektrum help
Hey im having a problems with my spektrum module the attena is broken. I want to no if there is an alternate casing or attena for it or can i send it in to the spektrum company if anyone has any advice or help i would really appreciate it.
Dwayne Island breeze II
Xray NT1 Xray T3
360 2.0
breez1090 is offline   Reply With Quote
Old 03-28-2010, 06:33 AM   #2
RoosterXp's Avatar
Trader Rating: 66 (100%+)
http://search.horizonhobby.com/index...d=127A4F6DB5A8
Go to this site, I had a broken antenna and my case was broken, (SR3100) and i got the antenna and case for 6.99+shipping. i was able to install the parts myself and my reciever looks perfect and like brand new!! youll probably have to look around on the site a little bit to make sure you find the right case, the antenna at least on mine just snaps into place. hopefully youll find it!
...to you it's a 6 pack, to me it's a support group.
RoosterXp is offline   Reply With Quote
Old 03-28-2010, 06:37 AM   #3
RoosterXp's Avatar
whoops my bad, i missread your post.. the module... what radio is it? you should still be able to find it on that horizon website..
Old 03-28-2010, 07:08 AM   #4
j_blaze14's Avatar
Trader Rating: 34 (100%+)
if its the antenna i think you need to order another, if its the wire splice the end of the wire about 1 inch and remove the plastic grey casing to expose the white wire underneath. worked on my helios spec pro module.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 03-28-2010, 08:32 AM   #5
Trader Rating: 23 (100%+)
Where did you find that on there? I need a sr3500 case and antenna also. Please help
tdt1805 is offline   Reply With Quote
Old 03-28-2010, 10:11 AM   #6
breez1090's Avatar
its a ko helios spektrum module the wire is not broke but the plastic antena is broken leaving the wire exposed
Xray NT1 Xray T3
360 2.0
Old 03-28-2010, 10:12 AM   #7
breez1090's Avatar
are you saying i should remove the plastic piece of the anntena?? and leave the wire hanging?
Xray NT1 Xray T3
360 2.0
Old 03-28-2010, 10:53 AM   #8
breez1090's Avatar
I LOOKED ON THE SITE DIDNT SEE ANYTHING FOR REPLACEMENT FOR MODULES I APPRECIATE THE HELP THOUGH
DO YOU IF I CAN SEND IT IN .....OR WHERE?
Xray NT1 Xray T3
360 2.0
Old 04-01-2010, 07:28 PM   #9
bl4
bl4's Avatar
Default SPEKTRUM SPMCP SIGNAL LINE VOLTAGE BOOSTER
Can this use on EP car and where does it connect from servo or esc to receiver?
Does it really help to prevent low signal better receiving?
Thks
bl4 is offline   Reply With Quote
SPEKTRUM HELP !! tornado Electric On-Road 13 12-18-2005 06:49 PM
