jr xs3 RX question
jr xs3 RX question
i got the radio but no receiver, can i use any 75mhz fm rx with it as long as the crystal matches the channal the radio is set to?
so it has to be a JR crystal? i need 5 receivers and im looking at the duratrax 75mhz fm because there 20 bucks a pop
i have an AE XP3D radio from an MGT that I wanted to use with my jr Radios RS310 recivers but my local hobby shop said the AE radio is not the correct shift to use with the JR recievers.
Good Luck.
TX and Rx crystals have to be from the same company. I tried mixing Futaba tx and Hitec rx crystals with a 75Mhz FM Futaba radio and hitec rx - didn't work. It worked when I used a Futaba tx and rx set of crystals. Should have worked with a matching set of Hitec's too.
JR radio is positive shift, I don't know about the DTX rcvr. You'll need to find out which signal shift it uses.
that sucks. for what those receivers cost, i think ill scrap the fm and go 2.4
whats the "shift" mean?
The easiest way I know to explain shift, and it's probably wrong, is that in a positive shift system, the frequency goes up from baseline when operating, and negative goes down.
There's an ad in the FS section right now for an XXtra and RS310 for $50/both.
The nice thing is that you'll never had to buy another crystal for either one, as they're both synthesized.
You could convert your XS3 to 2.4ghz. It's pretty straight forward if you don't mind a bit of soldering. It will cost about USD$35 in parts, including a receiver. Additional receivers are USD$20.
There's a thread about it here. You'll find an XS3 at post #6.
Been using it since December and it hasn't skipped a beat.
ordered the 2.4 kit today, i paid for ems shipping so i may pick your brain one day next week
