Which Speed Controllers For This Motor? Big Newb!
Hi, I'm not sure which speed controllers go with this fan motor,
hobbycity. com/hobbycity/store/uh_viewItem.asp?idProduct=6632
If it says that the power is 252W or 16 amps then is that the max power it can handle safely and do I need speed controllers that are in the 15 to 18 amp range for safe efficiency?
Like would this be a good one?
hobbycity. com/hobbycity/store/uh_viewItem.asp?idProduct=6456&Product_Name=Hobbyk ing_SS_Series_15-18A_ESC
Or maybe these are better?
hobbycity. com/hobbycity/store/uh_viewItem.asp?idProduct=4218&Product_Name=TURNIG Y_Sentry_18amp_Speed_Controller
hobbycity. com/hobbycity/store/uh_viewItem.asp?idProduct=6233&Product_Name=TURNIG Y_8-15A_UBEC_for_Lipoly
I have this speed controller already but it's 25 amps so I'm worried about frying something.
hobbycity. com/hobbycity/store/uh_viewItem.asp?idProduct=2167
Also is this battery good for the motor,
hobbycity. com/hobbycity/store/uh_viewItem.asp?idProduct=9267
If I understand it correctly you're suppose to multiply the constant discharge which is "30C" by 2.65 for that battery and then that gives me about 80 amps constant, If I get a speed controller at 15 to 18 amps then will it safely handle the constant 80 amps or does it not matter if it's higher?
Thanks!
Thanks!
Thanks!
Thanks!
