Is anyone running a mamba max on 3s with a 5700 kv motor?
Is anyone running a mamba max (not the pro) with a 5700 kv motor on 3s lipos? Only reason I'm asking is because I looked on castlecreations.com and it said the sidewinder should not be ran with 3s on a 5700 kv motor but you CAN run 3s and a sidewinder with a 4600 kv motor
since the sidewinder and mamba max have te same battery limit, I was asking if anyone is running 3s with a 5700 kv motor on the mamba max?
3s on the 5700 is fine with the Mamba Max or Max Pro. Sidewinder is rated for a max of 2s on the 5700. Have fun!
There you go! Straight from the man himself!
I run the 6900kv on 3s.. no problems at all for two seasons..
