2.4Ghz Tx and Rx compatibility guildelines
Sorry. A noob question that i always wanted to ask.
No experience with 2.4Ghz Tx / Rx.
If any RX (regardless of the makes), is able to share the same specs (see below) as the TX. Does that mean the RX is compatible with the TX and will work without any binding issues?
(1)、RF power:less than 20db etc
(2)、modulation:FM&GFSK etc
(3)、code type:PCM etc
(3)、sensitivity:1024 etc
TX/RX compatibility is only maintain when you stay within the same manufacturer. Even then, not all TX/RX are compatible. Read the manual for the radio, that is your best friend.
