ADDING larger wires to LIPO batteries?
How difficult would it be to add larger wires to a LIPO battery? I'm thinking of using a reciever pack lipo that would be the perfect size for a crawler and want to know how difficult it would be to open it up and re solder on some larger wires for deans connectors.
Any issues or tips if it's possible would be greatly appreciated. Surely theres an electrical guro here that would know.
Depends on the lipo, If the main power wires are directly attached to the cell tabs, its a matter of the right soldering equip - some tabs are copper and some are zinc - copper is easy, zinc requires a special solder and flux, both of which are corrosive and make toxic fumes.
Some lipos have small pcb inside where main power wires originate - another case that should be fairly easy to handle.
Usually these rcvr pacs have a low C rating and won't be much good for running a motor, but I don't know about a crawlers amp demand.
I did opened no. of Lipo's. Some of them does not made it possible to direct solder. The wires link are seal using welding equiptment. This is to prevent heat from spoiling the terminals.
if the tabs have already been tinned, you can soulder on them with no special equipment
I'v never had a problem as long as there is some solder still on the batt tabs
