Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 03-04-2010, 07:54 PM   #31
Trader Rating: 9 (91%+)
before you tear apart your multiplex, I belive corona makes a module for them, might be hitec but I belive it is compatable with both. May be wrong though, otherwise I would search for evo 9 or evo 12 conversion and that should help you with it.
interplanet is offline   Reply With Quote
Old 03-04-2010, 08:29 PM   #32
that module wont fit the proficar series radio
turbored21 is offline   Reply With Quote
Old 03-05-2010, 05:18 PM   #33
the wiring i posted has been officially tested on a spektrum module for airtronics and works perfectly im told so if you have a profi and want to do this mod thats the wiring setup to use
Old 03-07-2010, 08:45 AM   #34
Pita's Avatar
Default Ko Propo Helios
someone has done in a KO helios?
Club:
http://www.jerezrc.es
Fotos/Pics:
http://picasaweb.google.es/joselillo.ruiz "my pics"
http://picasaweb.google.es/jerezrc
Pita is offline   Reply With Quote
Old 03-07-2010, 08:53 PM   #35
Bugle's Avatar
I'm doing a EX-5 for a friend now, it has a separate RF board just like the Futaba 2PL so it's easy, maybe the EX-10 is the same have you looked inside it?
http://bugleboyracing.com/
http://stivesrc.org.au/
Bugle is offline   Reply With Quote
Old 03-08-2010, 12:51 PM   #36
Pita's Avatar
I have not looked, my idea is reassembled into the module, you should see how it communicates through the pins.
Club:
Fotos/Pics:
Old 03-08-2010, 12:54 PM   #37
Pita's Avatar
have pictures of ex-5, disassembled?
Club:
Fotos/Pics:
Old 03-08-2010, 04:00 PM   #38
Super Moderator
Funkymojo's Avatar
Location: Singapore ̡͌ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡V
Trader Rating: 75 (100%+)
Hi turbored21, so from the looks of it...it's gonna work with an Airtronics M8 and M11? If it does, i might wanna try it on my M8...
WANKING - Extreme agitation and arousal - usually south of Nanking and short of Farking.
I'm neither a Mod nor a Rocker. I'm a Mocker.
Viper R/C Solutions | Atomic Carbon CR2 LWB | Darth Tray | Losi 8IGHT 2.0-E | Tamiya TRF801X-E
Funkymojo is offline   Reply With Quote
Old 03-08-2010, 10:14 PM   #39
Trader Rating: 22 (100%+)
Default Rec
This may seem like a dumb question but here goes.
I have just bought a CJ8D corona system and would like to know if the receivers are polarity conscious. Also which channels are for what? eg power (from esc) throttle,steering etc. I will be using it in a JR-R1 for my offroad truck. Any advice accepted greatfully.
Terry
Is your car slow..Xray it!.......FK05, M18, M18t
RexX
Assoc...T3,T4, B4
Team Ash is offline   Reply With Quote
Old 03-09-2010, 06:09 AM   #40
PaPeRo's Avatar
Ch1 steering
Ch2 throttle
Yes the polarity has to be correct.
deans - dodgy electrics amps not sufficient
PaPeRo is offline   Reply With Quote
Old 03-09-2010, 01:41 PM   #41
Originally Posted by PaPeRo View Post
Ch1 steering
Ch2 throttle
Thank you.
RexX
Assoc...T3,T4, B4
Old 03-11-2010, 12:31 AM   #42
i had just come in to post actually the project had to get put on hold and has now been restarted.. and for whatever reason "might just be because its spektrum and not a diy" the module worked and bound one time to the RX from the proficar and wouldnt function after that.. he said he didnt think there was any damage to the module and was sure that the pinout was correct
so right now its at a standstill until i get a DIY kit and try it with the corona
ill be sure to post when i know 100% whether this will work fault-less with the profi series
Old 03-11-2010, 03:53 AM   #43
Default How about this one?
Hi.
I got this JR Pulse S AM Transmitter i'd love to be able to convert.
Anyone seen one of these to know if the mainboard sends PPM to the AM module?
Corona 2.4GHz diy kit - convert old radios to 2.4GHz-jr-propo-pulse-s.jpg   Corona 2.4GHz diy kit - convert old radios to 2.4GHz-internal.jpg
Mudgutts is offline   Reply With Quote
Old 03-11-2010, 10:49 AM   #44
Super Moderator
Funkymojo's Avatar
Thanks for the reply...Do keep us updated, i really hope it will work on a Sanwa M8/M11.
Old 03-29-2010, 03:13 PM   #45
scrawl's Avatar
For those who are using the Corona CT8Z, do you find the module reaching very high temps?
After 5 mins of usage, I'm noticing temps of 70C+. The regulator is hitting 90C+.
This came to my attention last weekend while racing on a hotter than normal day and having connection problems with more than one car throughout the day. I think the module has thermal protection which is cutting in after 3 minutes of use.
stivesrc.org.au
"It's a spending hobby. You race occasionally."
scrawl is offline   Reply With Quote
