New to E, NEED CHARGER $250 tops to spend
#31
I ordered the Hyperion 720i net 3 charger. I know I said I was getting the Icharger, but they seem to be having problems, bad soldering, quality control, etc from what I read on the rcgroups forum.
#32
The Hyperion is a fine charger but to be honest you can read about overheating issues with the Hyperion over at rcgroups. Either brand is fine.
#33
I just bought two of the turnigy accucel - 8's. Work like a charm. I highly recommend them. They are cheap too. Even with the high shipping costs from hobbycity, two of them would come in WAY under your budget.
#34
The Hyperions aren't perfect - I've had 2 0610iNet chargers (use 2) - one showed up DOA in the box and I had to send it back. I never plugged it in - it was not completely assembled - one of the end caps was off and there was a handful of parts and elect connectors loose in the box. My otehr 2 have been fine though.
#35
I guess every mfg has some kind of issues.
Duster, is your name referring to Plymouth Duster with 360ci?
#36
Scond one to ever ask - yes it is. I couldn't afford the 340 when I got out of college in 71 so had to settle for a 6cyl Duster. I put 282,000miles on it before I stopped driving it. Its slowly being converted to a 360V8, with V8 trans and rear end with disc brakes. I have all the V8 drive train, just need to start pulling it apart - has to have a new wiring harness and thats prob the biggest chore ahead. Rest won't be that much - just the work to get it done.
The Hyperions a fine charger, you'll enjoy using it.
#38
