You seem to understand everything correctly. The kV rating comes from the back emf of the motor windings. As the motor is spun up it will generate a voltage on its windings known as the back emf. (true for both brushed and brushless) You can think of the back emf as in series with the windings. When the motor is stopped, there is no back emf so the only thing limiting the current is the winding resistance. When the motor moves faster the back emf reduces the effective voltage applied to the motor windings, to the point where at max speed, the input voltage matches the back emf.
The kV rating comes from the amount of back emf that is generated at speed. Higher kV, lower back emf at the same rpm, high top speed at the same voltage.
The more turns there are in the motors windings the more back emf. (Voltage adds in series)
Reason: Added last paragraph
