Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-06-2009, 12:12 PM   #16
Razathorn's Avatar
Originally Posted by john stu View Post
6.6 sounds way too low to me...........
Yeah, with 6.6, you could store it right after LVC on your speedo -- I think they cut off around 3.25 or so a cell. Doesn't sound good to me either.
Hot Bodies D8
Kyosho Lazer ZX-5 FS
Razathorn is offline   Reply With Quote
Old 11-06-2009, 12:23 PM   #17
turbomeyers's Avatar
so if i use the batteries once a week do i need to put them in storrage (80%)for the week
turbomeyers is offline   Reply With Quote
Old 11-06-2009, 02:04 PM   #18
Razathorn's Avatar
Depends on how far you drained them. Lipos have self discharge, it's just very very slow. The purpose of the storage charge is to prevent the battery from going below 3 volts per cell and being damaged. If your battery hits the LVC on your last run, you probably want to put some in there just to be sure, but a full storage charge isn't needed. leaving too much charge increases the lipo's self discharge rate, which is why the recommended storage charge is around 3.8 per cell.
When I race, I just leave the pack where it was after the main till next week unless I break or don't get to run, in which case I discharge it to at least the storage charge level to ward off high self discharge rates over time.
Hot Bodies D8
Forum Jump
SMC send me this!! m3cosmos Electric Off-Road 15 09-16-2009 01:06 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
