cheaper batteries...will I regret it?
#16
I have not personally used those batteries, but I bet you will regret it. For running in grass you use alot of current from a battery, and I dont think 10C Nimh can take it very long. I have used several cheap no name batteries, some I had good luck and some I trashed within a few runs.
For a cheap pack these have treated me well. They have the same 10C rating, but I have used these pretty hard with no failures.
http://www.batteryspace.com/nimhbatt...2amprated.aspx
#17
They are considered on the same level as Tenergy and other chinese packs, but I used them with a MM7700 combo, so you know I put some stress on them. They all did great for me. Of course it likely helped that I bought loose cells and built packs with high quality bars and wire. But I had 12 cells 3300, and 12 cells 4200, both performed just fine.
