help with transmitter/receiver compatibility
Quite new to rc and just bought a used Futuba Magnum 2PL FM.
Anyway i'm looking to buy a few more cheap receivers to use in other cars.
Will the Airtronics 92836 work? It is fm and 75mhz.
I've read some stuff about pos and neg shift. Is it just backwards wiring?
Thanks, Pete
Thanks, Pete
Airtronics is compatible with JR. I'm not sure what Futaba is compatible with but it definitely doesn't work with Airtronics.
The positive and negative shift thing has to do with the signal transmission and cannot be switched by changing a couple wires around unfortunately.
ok thanks. It was the servos that needed switching now that i think about it.
