KO Propo EX-10 EURUS
#46
mdwaeracer- There are currently two systems for 2.4GHz, DS (Direct Sequence - locks onto a channel) and FH (Frequency Hopping - hops between all channels available). KO uses the DS.
Barry White- Only turned like the current module.
KDagh1- The DDS will only work with digital servos. We only test with our digital servos, but you probably find other that will work. We can only recommend using our servos. For gas touring, 2367 or 2368. For electric, 2413, 2345 or 2367.
wheruat - Thanks for the kind words and Happy Holidays!!
#47
#49
i believe that it will be about the same size as the helios. but they do make a gray rubber insert that you can get to make the grip bigger.
#52
BUMP.
Looking for an update to the arrival of this radio. Anyone know??
#53
I'm told within the next two weeks they should arrive here in the US.
#54
#56
#57
#58
Compatibility
Hi Ko Propo Staff,
I'm a happy user of the Helios for many years and thinking to upgrade to Eurus.
During the years, I have collected modules besides the FM module:
- AM-module for the mini-z
- Spektrum module, 2,4 GHz.
1) Will the Eurus supports de Spektrum module (SM1001 DSM)?
I have several Spektrum receivers (SR3500 micro) which will become obsolete.
2) Will it support the AM-module for the mini-z (RF-501 A).
Many thanks in advance for your feedback.
#59
Probably wont be able to post when they arrive because we'll be busy trying to ship them out. Tx only will not be offered at this time.
Mister-E - Probably will work, but we don't test out equipment with Spektrum brand products. Crystal modules (including AM) will work. Since all other modules (except RF-902S that comes with eurus) are not part of our Direct Digital System, the Tx will recognize this and slow the response down to PPM mode rather then the DDS mode.
#60
