Lipo for 3PM @ HobbyCity??
Trader Rating: 123 (100%+)
Looking for a lipo for my 3pm Radio and hopefully from HobbyCity since im waiting on the 4s 5000 packs to come back into stock I can order it then.
I'm "nervous" about ordering just any 11.1v lipo that "looks" like it should fit.
I would prefer one with 2500mah or so.
Any web wonders post a link to "the" pack?
Thanks!
Thanks!
Thanks for the reply, But...
I don't think that will fit in the 3PM... The 3PM's radio tray is shallow.. thin.. etc..
Oye.. this is my problem..
I'm running 3S lipo in both my 3PK and 3PJS - 3PM batt is the same size. If you have been using a tray, you remove that and use a piece of foam rubber. Connect the lipo, use the lipo to compress the foam, then slide the cover in place - the foam is needed to keep the lipo from moving around. Lipo by itself - it'll move around which is not acceptable
Here's the size that fits 3PK/3PM - Dimension(mm): 114 x 57 x 13mm
Don't think you'll find on on HC - this is more of a specialty batt. Look in A-Main, where I got mine, they are 3300mah and last a looooong time. Mine came with the foam included.
Duster_360 - Look in A-Main, where I got mine, they are 3300mah and last a looooong time. Mine came with the foam included.
Ok, got a link? checking Amain myself aswell...
Sure - your timing is great too -these were $85 when I bought mine -
http://www.amainhobbies.com/product_...k-111V-3300mAh
I have been running this one from Common Sense. Been good. Has built in cut off on the pack. Fits the 3PM great.
http://www.commonsenserc.com/product...roducts_id=260
Eh and full circle yet again..
Checked the ProTek RC lipo, nice nice nice... for $65
and checked the Common Sense Lipo.. nice too but again for $60
I really don't want to do the Bay thing for the $20 lipo's..
but it's looking more and more like a possibility
then you goota keep searching on hobby city
or build some your own
