AM. RC. Receivers Antenna Lengths
Ahoy, I am looking for the length of the antenna for"A". Hitech AM Receiver. HP-2RNB. Also "B" Futaba AM Receiver FP R122JE. Both antenna's are damaged.
These are both used on RC Sailboats. Thanx Reg Gregson
This may help - maybe follow the included link, those rxs are not specifically mentioned, but should give you some ideas on what you may need. I've always heard as long as replacement antenna is close to being right length, it'll do fine. As Alan points out some use same length across the freq range for given rx.
http://www.rcgroups.com/forums/showp...63&postcount=7
Here is another link that lead to finding the one above, you may want to read thru all of this -
http://www.rcgroups.com/forums/showthread.php?t=941709
Welcome to the forums, btw.
