Balancers
Balancers
Looking for a compatible balancer that will work with the Turbo 35 GFX. I was looking at this from Max amps, http://www.maxamps.com/MA-Method-Balancer.htm
any balancer will work as long as you can plug the balancer in between the charger and battery. just be sure to connect the small voltage sensing leads directly to the battery, or the charger won't read the voltage correctly. i use a checkpoint or blinky balacer on my T35 myself. both work fine.
