17.5 bl motor specs
17.5 bl motor specs
Hey all.
Can someone help me regarding 17.5 brushless motor specs and performance. Over here in New Zealand it looks like we will be adding 17.5 bl motors to our pro-stock (27t) class. Basicly I'm after some sugguestions as to what anyone thinks are the best ones to use. I'll be using an LRP sxx with it. At the moment looking towards the Lrp stock spec, trinity pulse or Speed passion.
Heya,
I'm fom NZ too
There isn't a lot of choice down here for brushless gear, as i'm sure you know!
I'm running 13.5 this year and have a Novak SS which is surprisingly good. I'm not sure about their 17.5 counterpart though.
I'd talk to the likes of Speedi in Ak and see what he stocks. It's always good to get from NZ with electronics if you can, as if you get from OS and have issues, it's a drama to send back for warranty repairs!
I've got Tekin esc's, so will probably go with a Tekin motor for my next one, but for no other reason than their ESC's are solid as hell, and i'm hoping the motors are of the same standard.
On paper, the LRP Stock Spec motors look pretty flash
I'm fom NZ too
I have been using a Tekin 17.5 in my SC10 and it is a good solid motor that dissipates heat very well. The LRP SS motors are very good as well and I have used three different ones over the last couple of years but the only one that I have now is a 10.5 and it rips.
The brands that you listed are all top notch manufacturers of BL motors and I would use any of them without a second thought.
Have run Novak, Orion, Hacker and Trinity Duo motors in 17.5. Definitely consider the Trinity Duo to be the best "open design" motor. The Hacker is best "closed design".
Thanks for that advice. Could you please explain the difference between "open and closed design".
Thanks again
Thanks again
Thanks again
Thanks again
Bill
