need help with connections!!
First off I just want to say that I'm a noob (beginner) in RC cars.
I just bought the Losi 8ight 2.0 nitro buggy race roller and finishing putting the kit together. Im having a problem with the wire connections and dont know what plugs into what. Any help would be appreciated.
Im using the Spektrum SR3300T receiver, 9100S & T high torque servos and have the Losi 7.4V 2000mAh 2 Cell LiPo Receiver Pack: 1/8 that Losi recommends to buy. Do I need to buy the voltage regulator (LOSB9608 or LOSB9609) as well? If so, how do i connect all of these together. The only thing I know is that both serves get connecting into the receiver in the THR & STR slots. Im left with a BIND slot and a AUX slot. Does the receiver battery get plugged into one of those slot? Im assuming the receiver needs power, right? How does the regulator come into play assuming i need it. Where does the switch come into play. The manual doesnt explain it well (they are probably assuming Im not a noob..lol). Does the regulator get mounted in with the receiver battery? I wish there was a wiring diagram/flow chart that i could follow or a website that covers the connections.
Also, which battery charger should I get? THe Losi LOSB9603 or the LOSB9605....one is 40 bucks the other is 140. The 140 dollar one maintains the cell balance better...or something....can i just get the cheaper one?
thanks in advance
thanks in advance
thanks in advance
thanks in advance
The manual from the radio should have a much better illustration of the connections than the buggy manual, by the way. You can download the DX3S manual from the Horizon Hobby website if you don't have it.
DX3S Quick Start Guide
DX3S Manual
somethings not right though. Losi recommends both the radio and receiver battery that i got, but the switch harness that the radio came with doesnt match up (or connect with) the receiver battery..which i dont understand...maybe the regulator (which comes with or w/o a switch ) is needed in this situation.
ok..thanks for the tip...i was confused because i was connecting a 3 pin to a 2 pin...ill just go ahead and do that thanks
