Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-16-2009, 10:15 PM   #1
Questions?? Servo grommets necessary for brushless setups?
Are servo grommets necessary for brushless setups to dampen any vibration.
If so, are the brass bushing inserts necessary because I can only find circular grommets for my JR 9100 on Ebay, but they do not show/include the brass bushings?
Jesse M is offline   Reply With Quote
Old 03-16-2009, 11:03 PM   #2
Drifting101's Avatar
Vibrations from/to the servo cant be stopped by grommets because when it bottoms out especially in offroad or a solid crash. Electronics will still feel it with a 1/2 inch of foam
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 03-17-2009, 04:03 AM   #3
Trader Rating: 15 (100%+)
I've never run grommets with any of mine, but I do use a servo clamp that holds the servo and prevents breaking the ears off the case. I'm of same mind as Drifting101 - grommets are not going to provide much in the way of dampening with the shock these things see in landings and tumbles.
Duster_360 is online now   Reply With Quote
Old 03-17-2009, 03:39 PM   #4
JeromeK99's Avatar
Servos have come a long way since the 70s.... if you are having problems wearing out servos from suspected vibrations, you need to get past the $20 servo and get something in the $50-$100 range. I have had top servos last 10 years of racing in all sorts of cars.
Jerome
JeromeK99 is offline   Reply With Quote
Tags
dampen , grommet , grommets , servo , vibration
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
