Futaba BLS servos and 2s lipo
I know that they aren't rated to handle 7.2v-8.4 but i goggled it and found some Helli guys testing and using them with out a regulator and with great results.My question is anyone on here using these servos a FASST 2.4 RX at this voltage and if so for how long?Secondly can an AMB transponder handle the voltage?
The other thing how is everyone monitoring the voltage of there there lipo (as RX batt)
I run the Futaba BLS451 in my drift car using the 4pk with 2s no issues.
i won't risk it.
i'm using a 6v 5A regulator for my 2S lipo with bls451...
If it's through the speed control, the BEC feature is lowering the voltage, the servo isn't seeing the full battery voltage. Speed controls normally provide 5 to 6 volts to the radio and thus servos in a typical electric car.
Are you powering the servo directly from the battery, or through the speed control BEC?
Has anyone used these at the higher voltage, without a BEC or regulator?
I Bence tested this today for about 10 min with no ill effects.Nothing got hot or warm even with constant servo movementWhat this meens probably not much
I Bence tested this today for about 10 min with no ill effects. Nothing got hot or warm even with constant servo movement. What this meens probably not much
My bad I guess I didn't read it well enough
And you would be right with out a load it doesn't really give you the whole picture. I can't remember from my electronics 101 days but as voltage increases current should drop I think... I can't remember if that applys to reactive or capacitive inductance... I don't know some one chime in and correct me.
