1/18th Sidewinder will not callibrate:(
I jsut built my new FT RC18T and I was trying to set the ESC and it would not work. I do the proper procedure and I get nothing.
The servo works, but the throttle will not callibrate.
Any help?
Any help?
hmm, might have to disconnect all and start from scratch. u said u have steering so ur rx is surely gettin power and is responding to radio. any lights? anything? no beeps? really faint beeps (sounds like a speaker with its amp unhooked)? check out the castle thread in the manufs portion of the onroad forum for more help. the castle guys will sort it out. i've had a balky speedo that was fussy bout a program b4, but givin it some time, restarting from scratch, usually will get things back going. do u have an castle link? did u use it already to change stuff?
R
R
What radio do you have? if it is futaba you need to reverse the throttle. other than that make sure your endpoints and trim are set correctly
Okay, I got the thing working. I had everything set correctly, but the problem was that the connector that plugs into the receiver from the esc was backwards
good thing u didnt fry rx in that moment
R
R
I is really an idiot eh?
Haha.
But really, so putting the connector in backwards could fry the RX? I guess I am lucky!
Thanks for all the help gentlemen. (and any ladies)
