Info on Turnigy Accucel 6
#46
The Accucel-6 has a 50watt limit, 14.8v x 5a = 72.5watt - above output power limit, 14.8v x 3.5a = 51.8watts - close enough to limit that charger will allow it.
The Accucel -8 has a 150watt limit and would do 5amps.
These 50watt chargers use slightly diff ways to stay under their power limnit. This one is limiting the current.
#48
hi guys... i have this charger and started using it recently. i'm charging bnew packs of flightmax 2S 5000mah lipos. i notice the balance charge does not finish... i keep reaching my time limit of 90minutes and even though the charge amps is 0.0 or 0.2A it still does not stop balance charging.
i read thru the discussion forum in hobby city and a guy also had the same problem. anyone has an idea about this? help. Thanks.
#49
#51
Yes it will finish when it is complete, but the charger has a built in timer that will shut off the charger no matter what, even if its not done, so you need to up the time limit or disable the timer so the pack can finish. Or you can just restart the charger. Your call there.
#52
i don't think i explained myself well... I'm charging at 1C = 5A for a 5000mah 2S lipo. around 60 minutes, the charging amp rate has gone down to .2A already... sometimes i see it reaching 0.0A. at that point isn't it supposed to stop charging because it's fully charged and no more amps are going in?
#53
Ok now we're on a different track! You will periodically see that happen when it gets down to the end of the balance charge. When you're balance charging you can push your right arrow button and it will show you individual cell voltages so you can see how well your pack is or isnt balanced. I def suggest doing this as soon as you have ran the pack to see how evenly your pack is discharging just so you know.
#56
Anybody know the calibrate procedure for the Accucel-6? There's supposed to be a button sequence you can hold at start up that lest you calibrate the voltage.....
If your lipos are coming off a under max voltage by more than just a little this is suposed be the way to resolve issue.
#58
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
-rocky b
#59
What brand and what size??
Calibration has nothing to do with balancing so that won't help you there.
flatspunout - Thanks - I knew the combo, but wasn't holding it when powered on long enough. I'm not doing anything fancy and have access to a uber expensive DVM if I need it, and the guy who owns it if I need them, lol! I want to set it so I get the same voltage that my Hyperions charge too, right now its a little low.
#60
duster and flat.... thanks guys for the inputs. i went into my calibration menu and the voltage is off by +.01. a good VM reads 7.67 but the accucel reads 7.68. so i calibrated and will now try to charge it.
duster: if you set to charge at 1C, isnt' that suppose to finish in an hour or a little after an hour? my time limit is 90minutes and i see the amps going down to 0.0A already, but still the charger is not finishing.
anyhow.. i will try to balance charge it for 120 mins. and see. i have the accucel 6 and charging flightmax 5000 2s1p. it's funny that the total charge amps surpassed 5000mah during balance charging. that scared me and i stopped the balance charging.
