Info on Turnigy Accucel 6 >
Old 11-18-2008, 05:51 AM
  #16
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Duster_360
Thanks for the tip. Going to order tonight, I'll make sure I get it right.
Good luck....it just made me wonder if it went threw or not the first time. I think I selected paypal by accident at first, when I wanted to use my CC. But you do get a shipping confirmation Email at least....and they ship via priority mail.
y2kgtp is offline
Old 11-18-2008, 07:10 PM
  #17
Trader Rating: 21 (100%+)
Mine is on the way!! Check out was pretty straight forward, but since you warned me, I was paying close attention and used Paypal to get 'r done.
This just comes withteh one type balance tap - the jst-xh type, right? I've seen other balance tap adapters for this on the HK site and when I order my zippys I'll prob get the other cables since I have a mix of balance taps.
Duster_360 is offline
Old 11-18-2008, 09:10 PM
  #18
y2kgtp's Avatar
This just comes with theh one type balance tap - the jst-xh type, right? I've seen other balance tap adapters for this on the HK site and when I order my zippys I'll prob get the other cables since I have a mix of balance taps.
Here is the side of it...it has a bunch of connectors, but I have not pulled the instructions to see exactly what they are.
My Proteck's I got from A Main plug right into the top left side connection here.....
y2kgtp is offline
Old 11-19-2008, 11:00 AM
  #19
Thanks for the close up - I see what I'm going to be dealing with - the plugins on that side are 2S thru 6S balance taps for JST-XH style taps. I have a pr of 3000 3S Protecs for my radios, so I can use it right away for those.
Old 11-19-2008, 03:29 PM
  #20
y2kgtp's Avatar
question....are you supposed to connect via the balance connector & the power connector at the same time? I've had some smaller lipos that I just had to connect via the balance tab, and that was it....
y2kgtp is offline
Old 11-19-2008, 05:47 PM
  #21
This is a balancing charger - you connect both sets. It balances while charging is ongoing. That way, you wind up with a fully charged, balanced lipo. Termed an active balancer vs a passive balancer which, after charging, just discharges all other cells to the cell lowest voltage.
Hyperion chargers, the 0610series, it makes a diff which order these 2 sets of cables are connected in. If manual mentions nothing about it, then it doesn't matter on this one.
I just looked at the manual - boy this little guy has got the features! Anyway, did not see preference for order in which both sets of cables are connected, so its not an issue. I know folks who say to cabel up completely with power off , then turn it on, set up and charge. I know others who turn charger on, then put cables on, then setup and charge. I've always done it with charger off, but looks like it really doesn't matter.
Old 11-19-2008, 06:23 PM
  #22
y2kgtp's Avatar
Ok...that works for me...I just wanted to make sure I plugged both in at the same time
y2kgtp is offline
Old 11-21-2008, 10:28 AM
  #23
Originally Posted by y2kgtp
...... But you do get a shipping confirmation Email at least....and they ship via priority mail.
Wonder if something went wrong, I've never got an email after my order??
Old 11-21-2008, 10:38 AM
  #24
y2kgtp's Avatar
It took a day or 2....
I got an email from the following with my tracking number...
hexTronik Limited <[email protected]>
y2kgtp is offline
Old 11-21-2008, 03:11 PM
  #25
Spam ought to be against the law....I had spam filter set on exclusive, so if they sent me something, it was bounced or killed. I did go to their site and pull my account up - says it shippped 11/19, so everything's cool.
Should have it in next few days!!
Old 11-21-2008, 03:12 PM
  #26
y2kgtp's Avatar
Prob Tomorrow, Monday at the latest....
y2kgtp is offline
Old 11-21-2008, 03:16 PM
  #27
Figure Mon - pkgs are starting to slow down, its that time of the year again....and besides, I want to see it bad, so I know it won't get here tomorrow, lol!!
Used yours much yet??
Old 11-21-2008, 03:19 PM
  #28
y2kgtp's Avatar
I need a eflight extention for the charger....a 2" lead is not enough as the charger is almost in the lipo bag with the battery!
y2kgtp is offline
Old 11-21-2008, 03:33 PM
  #29
y2kgtp's Avatar
I just soldered some deans on a couple batteries, and trying it out now....it reminds me alot of a Triton menu system....but this is nicer as back-lit, and also gives you individual cell voltages as your charging.
y2kgtp is offline
Old 11-24-2008, 06:20 PM
  #30
Got mine today and its finishing on its 4th batt of the evening, 7 cell 4400mah NiMH pack. Very impressive for its small size. Will have to wait for lipo until i get some adapters, but have no doubt it will take care of those like it does the NiMhs.
What a great deal!!
