charging 8 AA batteries for M8 adapter...
i bought a used M8 and i am using 8 AA nimh batteries to power it... there is a plug for an adapter on the bottom of the AA battery tray but it didn't come with the adapter... i'm wondering what spec adapter do i need to get so i can charge all 8 batteries at the same time without having to take them out of the tray...? thanks...
i still use a wall unit that charges both rx packs and tx packs. u could hack off the tx part and put ur fav connector on the other side if u desire to charge off ur primary charger.
sadly up til the advent of lipo batts, i preferred to use a double vision charger that did tx/rx/glow all at same time. even had polarity switch for folks that had jr radios which are wired backwards.
check out all the adaptors/dongles on horizon, sure u'll find somethin u can use there
http://www.horizonhobby.com/Products...rodID=HRC56371
R
R
