hai RCGaryK ur the guy that on youtube promote DX3S rite ?
wow glad to know u are here OUR Spektrum DOctor !~~ LOLZ ... i already send a message to horizonrc.. waitting for reply.. anyway i will copypaste here again... let u c ... i belive that u will know MOre than everyone have spektrum because at my LHS they can't help me ...
here as below
i already have no idea what shall i do now... my Local hobbyshop can't help also already they totally can't slove my problem...
ok let get this straight forward..
i get my DX3S last year shall be around november or december..
So i open the box just like the way i follow the instruction book.. the SR330 Work Perfectly without a problem.. only the SR3300T have problem for the fail safe..
ok i will explaint one by one ...
After i finish blind the fails safe position everything works fine ..
So i make a test on it... when the RX power was on so i switch off the Radio power
it will keep brake for Few Sec.. after that it goes back full Throttle !!! (note because when i off my radio i was gave it full throttle for test it will goes back to brake position or not..) really very weird happen...
i keep redo again and thing also happen the same to me...
My main problem with the SR3300T is
It will load back to the last step when the signal is lost..
so after that i take another DX3R for testing to blind the SR3300T it work fine !!! the fails safe toos !!!
HELPPPPPPPPPPPP what shall i do ??!?!?!? my local hobbyshop can't slove my problem already...
donno is my Radio problem or my RX problem...
i really have no idea o..
here is summery i make
SR3300T issue ~
- I use SR330 without telemetry RX that come with DX3S it work perfectly
- I Try it out SR3300T with Telemetry the fail safe pull few sec and back to last radio command (example if i use full throttle and single lost it wil keep brake for few sec and pop the full throttle again
- I try the SR3300T blind using my another Dx3R the fail safe work perfectly...
- If i thinking of my RX failure why if i use DX3R blind it work perfectly..
But i been thinking that my DX3S radio problem so why the rx without telemetry work perfectly ??? HELP is sooooOO complicated !!!
So Why ? WHY This HAPPEN !?!?!
thx again anyreply in this would be highly appricated .
best regard's
fei
thx really thx !! i REALLY REALLY REALLY NEED HELP !!!
