Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 09-23-2008, 10:50 PM   #1
Foxxrocket's Avatar
Default charing smc 5000 on ICE charger
I just switched to LiPos with a smc 5000mah battery and ICE charger. I was wondering if anyone with a lipo battery and same charger could help me with the setup in efficiency charging. I have it set to 5000mah, but charging is agonizingly slow.
Liop 5000mha
7.4V
charge 1.0A
discharge 2.0A
discharge cuttoff 3.0V
cuttoff temp 90
max charge charge cap 100%
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 09-23-2008, 11:57 PM   #2
padailey's Avatar
Liop 5000mha
7.4V
charge 1.0A
discharge 2.0A
cuttoff temp 90
Max out your charge rate which will end up being 5.0A. As you've noticed charging at 1.0A is very slow for that size battery.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 09-24-2008, 12:55 AM   #3
bmxRRT's Avatar
LiPos should be charged at a 1C charge rate, this means whatever mAh battery you have you can charge it at X.Xamps. 5000 = 5.0amps, 3600 = 3.6amps etc....1amp will take forever.
bmxRRT is offline   Reply With Quote
Old 09-24-2008, 03:18 AM   #4
Foxxrocket's Avatar
Great, that sounds simple enough.
Thanks guys
Old 09-24-2008, 10:52 AM   #5
Trader Rating: 21 (100%+)
The Ice has one of the better manuals out there for a charger. It explains a lot about the diff batt types. Its worth reading, especially if you're unfamilar with batt you're charging.
Duster_360 is offline   Reply With Quote
Old 09-24-2008, 12:56 PM   #6
you charge everything lipo at 1 c, so for a 5000 it's 5 amps for a 2100 it's 2.1 amps.
wolf@ma is offline   Reply With Quote
Ice, Checkpoint Charger, Powersupply I LIKE IT XXX R/C Items: Wanted to Buy 2 01-21-2008 03:47 PM
You think an ICE charger is my best bet? z28mccrory Radio and Electronics 15 12-22-2007 03:42 AM
MF2 - Duratrax Ice Charger - Novak 8.5 brushless - Stampede speed lives R/C Items: For Sale/Trade 21 12-13-2007 09:55 PM
charging receiver battery with ice charger serpentpro28 Electric On-Road 1 07-25-2006 12:16 AM
Help with Ice Charger 748eric Rookie Zone 20 02-21-2006 09:28 PM
