Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 09-23-2008, 02:12 PM   #1
STRINGCHEESE's Avatar
Default Quick Advanced lipo question
If I take 2 x 1500mah 20c 3s packs and wire them in parallel, what do I get?
I know I still get 11.1V, but what happens to my mah and "C" rating?
STRINGCHEESE is offline   Reply With Quote
Old 09-23-2008, 07:04 PM   #2
Super Moderator
A 3000mah 20C 3s pack.
Assuming you started with 3s1p packs, now you have a 3s2p.
You do get twice the current or twice the run time as one pack. But the same C rating if you call it a 3000mah pack.
Dave H is offline   Reply With Quote
Old 09-23-2008, 07:25 PM   #3
Trader Rating: 21 (100%+)
^^^^ Exactly. Lots do the same thing as a way to feed amp hungry setups. Your continuous amps wired in parallel doubled, becoming 20 * 3 = 60amps.
Duster_360 is offline   Reply With Quote
Old 09-24-2008, 02:39 PM   #4
So, if I'm using a 30 amp (40 amp burst) esc and wire two 3s packs in parrallel that are rated for 20c I should be ok?
Question on charger for lipo on Micro T...Help Paul Whalen Micro and Mini Scales 5 06-15-2008 11:21 AM
question on lipo pack for a receiver charlesd Nitro On-Road 11 06-07-2008 12:53 PM
Lipo receiver pack/regulator question thecman26 Nitro Off-Road 16 05-06-2008 02:56 PM
lipo question... leigh18 Electric Off-Road 1 04-28-2008 01:58 AM
Quick Servo question semore Electric Off-Road 1 01-28-2006 11:32 PM
