Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 09-11-2008, 04:09 AM   #1
Default HELP! ICE charger and Hyperion lipo balancer
Hi All,
I have recently upgraded to lipo's, intellect 25C 3800mah and 5000mah. I also bought a Hyperion EOS LBA10 balancer, as the Duratrax ICE charger does not have an inbuilt balancer. I had to rewire the balancer to accomodate for the battery not having a cable. Having all the components connected the charger automatically sensored that the battery was not connected? Has anyone had any experience in using a balancer with the Duratrax ICE??
Thanks in advance.
Natos
_____________________________________________
TRF415 - Novak GTB 3.5
TRF415 MSXX - Novak GTB 8.5
Natos is offline   Reply With Quote
Old 09-11-2008, 07:26 AM   #2
I know when I use it with my GFX I have to push the black button on the balancer one time so the green light is off. maybe it's the same for you
-=light=-
light is offline   Reply With Quote
Old 09-25-2008, 01:37 AM   #3
Mr.Maim's Avatar
Trader Rating: 36 (100%+)
Natos,
I have an ICE and use Electrifly Equinox balancers for my flight packs. With the Equinox, I press the black button so that the "Interface Mode" light lights up, then I hit the charge dial/button on the ICE.
I downloaded the manual for the Hyperion balancer and have to admit that it doesn't work the way any other balancer that I have ever seen before works. You have to connect the balancing jack from the battery, AND the main power output from the battery to the blanancer? Weird. Never seen that before.
The Hyperion balancer manual is pretty clear. Are you sure you re-wired it correctly?
Mr.Maim is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
SMC 28C 4000/5000 Hardcase Lipo part 2 Danny/SMC Electric On-Road 1598 02-17-2009 08:20 PM
E-Revo Conversion? Unoversace Monster Trucks 34 10-23-2008 11:18 AM
Help me buy a good LiPo Charger markhat250 Electric Off-Road 32 08-29-2008 09:51 AM
LIPO HELP NEEDED!! Yevins Rookie Zone 8 07-29-2008 04:59 AM
Lipo charger help needed. (choices) LiveLarge44 Electric Off-Road 29 06-01-2008 09:32 AM
LiPo charger advice: Hyperion ac/dc vs. Orion avionics advantage jubilee Northwest Racers 19 03-11-2008 04:04 PM
