Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 09-07-2008, 06:10 AM   #1
Renault_Tech's Avatar
Default discharging Ni-Mh question.
hi all. I have an Intellect NiMH Receiver flat battery pack 1400mAh 6V 2/3A and was wondering what level and rate i should be discharging this pack till if i know i wont be using it for a while? Thanks in advance.
Renault_Tech is offline   Reply With Quote
Old 09-07-2008, 10:27 AM   #2
Trader Rating: 21 (100%+)
I assume this is a recvr pac from th voltage? I disch mine at 0.5amp and charge at 1amp. If I don't use mine at least once a month, I cycle them 3 times and they come back to full capacity.
Duster_360 is offline   Reply With Quote
Old 09-07-2008, 10:52 PM   #3
Brandon A's Avatar
I've heard mixed reviews about how much charge should be left in Nimh's for storage. I do know that you never want them to go completely dead as this will damage the pack. I have heard that for long term storage packs should be fully charged before they are put away however my packs are usually only stored with about 50%. They definately will need to be cycled a few times after storage but should come back quite nicely.
RCAmerica/Xray <> Panther <> RW Mods
Brandon A is offline   Reply With Quote
Old 09-25-2008, 04:57 AM   #4
Forgot i posted this! What MAH do you drop them down to Duster??
Old 09-25-2008, 05:14 AM   #5
If I'm storing mine, I charge it fully - NiMH self discharge, so starting at 100% will prevent them from reaching absolute zero the longest. I don't let them go more than a month without activity however. Long term is something else - months or years?? If I was looking at that kind of time frame, I'd plan of getting new and consider selling off the ones I have before quitting.
Cycling works great, 3 cycles seems to bring them back - you can see it in the discharge, the 2nd will be much beter than the 1st and the 3rd will only be a little better that the 2nd. If there is still a big diff 3rd to 2nd, I cycle them some more till I see the discharge numbers stabilize. Ice charger makes this easy - I let them cool 10min between discharging and charging.
Discharge Rate Question. wade7575 Electric Off-Road 18 02-29-2008 04:44 PM
ROAR approve LiPo packs..... c1 racin Electric On-Road 7 01-17-2008 05:38 PM
Nooby Super Brain discharging help, please. oMONSTERo Electric Off-Road 10 05-24-2006 09:34 AM
GMVIS commander disaster999 Electric On-Road 26 12-25-2003 05:10 AM
