problem with my m8 radio
hey guys got a little problem with my m8 radio or maybe its not a problem at all.
here we go i have the epas set so i thought was right and i was told by airtronics and hitec that the radio at max epa will turn 45 degrees left and 45 degrees right depending on the servo im running hitec servos and my steering does the 45 and 45 but my throttle does 90 degrees and 45 degrees on brake is there a problem or not ??? i also have a mx-3synth that i turned on to chedk it and its full epa is 45 on all 4 so why would my m8 do that. is there something wrong with radio or ??? all my epas are set good now but just courius thnx will g
Will, I dont think the M* has the same reverse throwadjustability that is has for forward.
Will, right on, glad you got it to work.
take care.
Pete
take care.
Pete
