Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 04-28-2008, 11:22 AM   #1
pink_sleeve's Avatar
Trader Rating: 105 (100%+)
Default JR9000S Jitters
The servo jitters like it is trying to center so i opened it up to see if the gears are bad but they all look fine so i'm confused. When it's together though and the servo horn is on when you turn it there is a touch of free play so something has to be messed up. The only thing i see that looks odd is the top of the case where the gears are is that the center gear that has the bushing that seats in the case at the top looks to be oblonged to me? Could it need a new case or am i overlooking something. They have 3 year warranties but i lost my receipt and the hobbyshop i bought it from went out of business last may or june so what can i do?
pink_sleeve is offline   Reply With Quote
Old 04-28-2008, 11:41 AM   #2
Administrator
mr. losi's Avatar
i have a ko servo that does the same thing...
Hurricane Motorsports-SPeedLIne Designs-BCE- KT Hobbies...(RIP)
mr. losi is offline   Reply With Quote
Old 04-28-2008, 09:30 PM   #3
Administrator
pc9840's Avatar
Send a message via ICQ to pc9840 Send a message via AIM to pc9840 Send a message via Yahoo to pc9840
Just send it in for service. There were some motor issues that I know of with the 9000 series servos. Although this doesn't sound like a motor issue they will probably just send you a new one.
Jesse@pc9840.com <><
"The minimum wouldn't be the minimum if the minimum wasn't good enough"
pc9840 is offline   Reply With Quote
Old 04-28-2008, 10:27 PM   #4
Trader Rating: 37 (100%+)
i had the same problem and the top of your case is most likley bad. I wouldn't think that is causing the jitters. I would send it in they have excellent service.
nitro neil is offline   Reply With Quote
Old 05-06-2008, 08:04 AM   #5
Trader Rating: 14 (100%+)
I have a 9100s that is 3 weeks old. It has some play but no jitters. I would send it in. JR has the best warranty.
infanterene is offline   Reply With Quote
Old 05-06-2008, 04:33 PM   #6
dethklok151's Avatar
Trader Rating: 23 (100%+)
yes.it is probably the top of the case.it is a common pproblem if they last long enough.with a digital servo,any slop will give it the jitters,as it cant ever really find center.try writing while you hold a pen so the pen is as long as it can be,then hold it close to the point.same theory.when the tires are on the ground,your jitters might go away,as the friction of the tires on the ground will hold pressure on the servo,one direction or the other,which will help allow it to calm down.the slop in the gear train and case will let the little gears "bounce"from one direction to the other without moving the horn,so the servo is constantly going back and forth.digital servos are that accurate.it is called "deadband".digital servos allow you to adjust deadband,which requires a programmer,around 120 bucks i think.reprogramming the servo deadband could also help,but i have not tried it.giving it a wider deadband would make the servo center less accurately,so as you turn left then let go of the wheel,the car would most likely still pull to the left,then if you turned right,and let go ,it would still pull to the right.
replacing the servo case will most likely fix it.
"hey buddy,ya gonna finish marshalling my car or just lay there and bleed?
dethklok151 is offline   Reply With Quote
Old 05-06-2008, 06:08 PM   #7
Thanks guys i put a new upper half case on it and the jitters are gone. I figued it was the case since the whole being dameged was allowing slop in the gears
Forum Jump
WTB - JR9000S Digital Servo superx421 R/C Items: Wanted to Buy 0 04-27-2008 10:59 AM
NEW - Losi 8T - VSpec - JP3 - JR9000S/9000T fytefire R/C Items: For Sale/Trade 3 03-12-2008 02:41 PM
Pre-Race Jitters? Or just nuckin futts? mrrcguy Electric On-Road 23 08-20-2007 12:50 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
