M11 HELP!!!!! Cutting out???? >
Old 04-22-2008, 08:12 PM
Default M11 HELP!!!!! Cutting out????
Hello,
I am brand new to the sport and brand new to the M11 radio. I just bought a used M11 radio, used it for the first time tonight, and have a BIG problem. I bought it and it already had the antenna mod done to it. Does doing this mod effect the signal at all. I was standing in the middle of the track, and if the buggy went up and over a berm (literally 30-40 ft. away) to where I could not physically see it, it would loose signal and the throttle would stick WIDE open. I was using a BRAND NEW 1600 hump pack and the radio was ready the batteries in it at 9.9V, so I don't think that is the issue. Could you please give me an idea of what the problem might be. I checked the connection with all wires inside the battery box on the buggy and everything looked fine. Any help would be GREATLY appreciated. I hope to race this coming Friday assuming I can get this situation figured out. Has anyone else had this problem, especially if you have the mod done to it. I don't know why, but I just wonder if that has something to do with it. THANKS!
Blake
superx421 is offline
Old 04-23-2008, 12:33 AM
imaxx21's Avatar
the antenna mod has everything to do with range...
prolly a loose or poor connection inside the radio where the mod as done
imaxx21 is offline
Old 04-24-2008, 08:52 AM
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Also Hold the brake down and rebind, It wont run away if it lose's signal again.
Jason Pelletier is offline
Old 04-24-2008, 10:28 AM
R/C Tech Elite Member
CCristo's Avatar
Trader Rating: 56 (100%+)
I've never had a problem with my M11 with the modded antenna. I did have problems with the receivers getting dirt/dust in them and causing weirdness. Open the receivers case and blow them out with air or spay them with motor/electronics cleaner
CCristo is offline
