i used to read thead about ex-10 radio but can't find it anymore.i need help with my radio's steering balance.followed steps on pg.50 in my manuel but it doesn't work.i bought radio used if it matters.can't get star to move bal. values at all,tried the hold pos. neg. bottons at same time does noting ,can someone please answer and help me out,thanks
On my KO Mars, you have to select steering balance, turn the wheel fully left, and adjust using plus and minus buttons. Then turn wheel fully right and adjust using plus and minus.
I assume that the EX10 will be similar.
If you have end points or steering trims set they will effect you ability to modify the steering balance.
yup! make sure you zero out your steering trim first. i usually just COPY over the existing model with a default model so that everything is set back to factory default, then i readjust my ESC, servo, steering..etc.
Sponsored by:
REI | Coleman | Patagonia | The North Face | Camping World
http://video.about.com/camping/How-To-Build-a-Campfire.htm
Motto: A sniper who has a grassy knoll on lockdown.
