Radiomaster MT12
#421
There are two ways to connect to Wi-Fi: one is to connect the EP2 to your home network, and the other is to use the EP2 itself as an access point.
I'm having trouble connecting to my home network, so I always connect directly to the EP2's access point.
The binding phrase is specified when flashing the firmware.
#422
I like the down-position steering wheel, but I don't like the drop-down style.
I actually wanted to rebuild the case itself, but that wasn't realistic, so I had no choice but to make a drop-down mod.
I've lowered it a little too much, so I'll adjust it a little more.
The more important problem is that it no longer fits in the MT12's transmitter bag. Does anyone know of a nifty bag that can store a drop-down MT12?
#423
Programming
Hey everyone so I just got my MT12 last week got it all set up I’m all of my cars I’m slowly figuring things out. But still so much to learn.
My question here does anyone know if you can set switches to adjust like the Throttle EPA? On my X-RAY XT2 I had to slow the throttle profile down quite a bit to keep traction at the race this weekend. But I went to far and didn’t have enough speed once racing. Obviously this is something to figure out in the Qualifying rounds or practice and not the main. But still just thinking if I could adjust that on the fly with like p1 or p2 dial like the multi switch on a Traxxas TQ would that. that would be rad. I’m sure it can be done I just don’t know how
#424
https://youtu.be/DcJnIJSHdgg?si=ps3FSUqpanFZnPuU
#425
The steering wheel has been adjusted to almost the best position.
I also want to make my own hand grip, but it is extremely difficult to create 3D CAD data for this.
#426
I found a nice bag (h ttps://www.aliexpress.com/item/1005005602817829.html?pdp_npi=4%40dis%21JPY%21%EF% BF%A5%207%2C528%21%EF%BF%A5%202%2C484%21%21%21341. 96%21112.85%21%4021014a8d17156707908471656d6246%21 12000033716809052%21sh%21JP%21716785489%21&spm=a2g 0o.store_pc_aeChoiceSimplified.allitems_choice_200 5544669264.1005005602817829).
A modified MT12 can be fitted with simple cutting. If only the antenna is removed, it can be stored with the external module still attached.
#427
Hi guys, I'm starting back on RC cars after 15 years more or less.
Should I choose the ELRS or 4IN1?
Today I have none receiver, and I'm thinking to buy this radio due to price and features like selecting position of trigger, spring tension.
Thank you!
Thank you!
#428
Super Moderator
#431
Model data can be found here.
The modification is almost bolt-on, but it is necessary to extend the wiring of S1 and S2.
This data includes:
steering position mod
Feather touch switch B
trim5 mod
This data includes:
trim5 mod
#435
This data includes:
trim5 mod
This data includes:
trim5 mod
Did you use some open source software like onshape to draw it?
