My RC's stopped responding - Please help
Today, trying to figure out a problem of a steering issue of the servo, I tried to connect the servo of the other car on my main car's ESC. That time I loose connection of the one car and when I try to turn on the other, I loose that one too.
First car is the stock HPI sprint 2 and the problem I have is that the ESC's led won't stop blinking while I got no control over the speed or steering. I followed the binding process again. Looks like I'm bound but nothing is happening.
Tx: TF-40
Rx: RF-40WP
ESC: SC-3sWP2
Second car is the Kyosho TF-5, on this one I can control the steering but not the throttle...
Tx: Flysky fs GT2G
Rx: FS-A3
ESC: Robitronic Speed 2 Star speed control
It's been hours I am trying to bring them back to life, searching on the internet, watching videos but no luck. I wish you can help me find a solution because I am really sad loosing both cars like that...
Tx: TF-40
Rx: RF-40WP
ESC: SC-3sWP2
Tx: Flysky fs GT2G
Rx: FS-A3
on 1st car check servo and bec on esc.. ..if you have 4 AA try that as a bec don't forget to remove center wire on esc..
on 2nd recalibrate esc to radio..try that or switch rx on that car..
Yes the cables are set correctly. The receiver ports give 5v so I guess the becs are all right? How do I calibrate any of these? They got no buttons and I can't find any info on this...These are the cars I want to FPV but haven't tried it yet.
After reading the manual and getting some help I finally fixed the HPI. Now I am working on the Kyosho which has the Robitronic Speedstar 2 (automatic setup version without setup button) ESC which appears theres no manual for it, and the flysky fs-gt2g which has no manual available either.
So I did the binding proccess again and it looks like I am getting signal only on channel 1 which is the steering. The ESC also works on channel 1 and I can throttle or reverse with the wheel so I guess the ESC is fine. On channel 2 is dead but gives volts to the servo and channel 3...
What can this mean?
What can this mean?
What can this mean?
What can this mean?
The manual for the GT2B is available online if you just look.
The Flysky radio is I believe a dual output transmitter. Both FHSS but different protocol's. One is ADHS and the other is AD something else. I could be wrong with the designations but there are two separate protocol's. Make sure you are on the correct one. There is a Flysky sub forum. Check it out.
Sounds like a blown receiver.
The manual for the GT2B is available online if you just look. Here is a copy I found this morning;
https://drive.google.com/file/d/1mIx...ew?usp=sharing
Try to set channel 2 (throttle) to REVerse signal on your transmitter. Or when already in REVerse, set to NORmal direction.
