Tekin T8 2250KV truggy motor problem
I was just driving my truggy when all the wheels locked up. I take the motor apart and it looks like the rotor magnets broke. Has this happened to anyone else? It also looks like it took the sensor out also. Is there a way to check the windings or is this now just an expensive paper weight? Thanks for any help.
R/C Tech Elite Member
Can you get a new rotor for those? I dont think Tekin sells rotors separate.
Brushless motor check
Check out this guide, it should give you some info on how to check out the winding's.
The rotor can be found here
If you need a sensor board, here
