Go Back   R/C Tech Forums > General Forums > Racing Forum
Old 09-20-2016, 12:21 PM   #1
Pekr.da.skurl's Avatar
Default Stadium truck tires on carpet
Do people run the mini pins in the front and rear? Thanks
Pekr.da.skurl is offline   Reply With Quote
Old 09-20-2016, 01:43 PM   #2
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
You can, or you can use these on the front: http://www.racing-cars.com/pp/Manufa...her/U6708.html
MarkA is offline   Reply With Quote
Old 09-20-2016, 02:06 PM   #3
Thanks. I never seen those before.
Old 09-20-2016, 02:58 PM   #4
Used the mini pin rears and stagger fronts with good success. They almost have too much grip. Make sure your ride height is low. I've also played around with AKA Chainlinks in front to give me a little push in the turns to help me cut down on traction rolls.
BruceR. is offline   Reply With Quote
Old 09-20-2016, 03:22 PM   #5
johnnyshore's Avatar
Trader Rating: 72 (100%+)
Most guys around here that run on astro run these...
https://www.amainhobbies.com/schumac...EUYaAnGy8P8HAQ
Full pins in the rear, and usually just the V's in the front (trim off most of the pins), with the outer edge of the tire superglued.
John Schroer
Check out Shamrock R/C Raceway
Minnesota's only outdoor astroturf off-road track!
https://www.facebook.com/ShamrockRC/
johnnyshore is offline   Reply With Quote
Old 10-06-2016, 01:05 AM   #6
DJ919's Avatar
Thumbs up
Stagger Rib" 2.2 1/10 Truck Front Tires, in yellow compound
Schumacher "Vee 2" 2.2" 1/10 Scale Stadium Truck Rear Tires, in Yellow rubber compound
Amain Hobbies Works like a charm, your truck will be a magnet!
I use to be fast >>> A very long time ago.
www.facebook.com/DJ919
DJ919 is offline   Reply With Quote
Old 10-06-2016, 07:55 AM   #7
Tim W.'s Avatar
I run the Schumacher Stagger Rib fronts with the outer rows trimmed down and the Schumacher mini pin rears on my T5M. The truck is glued to the track!
Mugen Seiki, AKA, Werks Racing USA, Flashpoint, Upgrade
Tim W. is offline   Reply With Quote
