2nd Annual Southwest TC Championship Hosted by SRS
#16
Any Roar legal stock motor with fixed timing will work. There will be a tech table were you will need to get your car will be check prior to each heat for weight (1525gm min), that the proper motor is has been installed, and you have the correct tires on the car. As far as bodies go pretty much any touring car body should be fine although you might want to double check with Scott at SRS to make sure. Last year the rules for bodies were not very strict. Basically as long as it was a touring car body it was fine.
#17
Not sure but I don't think you can run novice and stock at this race you may want to talk to Scott before you sign up.
#18
TTT
#19
TTT
#21
I don't know exactly what the price is going to be this year yet because they still need to find out if it the tires are going to be RP30’s or CS27’s. Last year they were $25 a set for pre-mounted CS27's. You could get a total of 3 sets to race on per class and could buy extra sets for practice. You can run your own tires as much as you want in practice. For the race you will need to run a set of the hand out tires. Hope this answers your questions.
Eric
Eric
#22
No personals SRS doesn't have the new system hand out transponders, tires will be about 30.00 store cost went way up tires will be cs27 pre mount
#23
ttt
#24
OH YEAH, I COMING OUT AGAIN. Dave, you going to be out Friday, I have to knock the rust off the TC for this. Time for some new packs and motors. Mac, do you plan on making the A-main this year??? This race was a blast last year and should be even better this year. Hopefully we get an even better turn out!
#25
dave-Hopefully. I still need to put that belt back on my car and seriously check the tweak. Full Pinned+Wall=BAD. LOL. See you soon buddy.
#26
Oh yeah I will be there have a new toy that I am trying to get ready for the race see you fri.
#27
ttt
#29
dizzy-LOL.
#30
The tires will be CS-27's.
