MBRC "Mushroom Bowl" 2nd Annual Short Course TRIPLE CROWN Event!, (SE Pennsylvania)
Yep, it's BACK again! The Short Course TRIPLE CROWN is HERE!!!
The ULTIMATE R/C driving challenge is coming back to the Mushroom Bowl this October!
Test your skills on THREE different surfaces at the ONLY facility setup for an event like this.
Race your Short Course Truck on the Off-Road track, the Dirt Oval, and the On-Road Asphalt track and see how you compare to the other top drivers in the area!
The following classes will be running:
-- 2wd Short Course 17.5
-- 2wd Short Course MODIFIED
-- 4wd Short Course MODIFIED
The following prizes are being offered for EACH class:
--1st Place: $300.00, Trophy, T-Shirt
--2nd Place: $200.00, Trophy, T-Shirt
--3rd Place: $100.00, Trophy, T-Shirt
--4th Place: $50.00, Certificate, T-Shirt
--5th Place: $50.00, Certificate, T-Shirt
--6th Place: $50.00, Certificate, T-Shirt
--7th Place: $50.00, Certificate
--8th Place: $50.00, Certificate
--9th Place: $50.00, Certificate
--10th Place: $50.00, Certificate
--Additional Bonus winnings for each class within each SURFACE:
-- $50.00 1st Place
-- $30.00 2nd Place
-- $20.00 3rd Place
--Top Qualifier certificates and $25.00 given for each class on each surface.
** Each class will have 3 Qualifying heats on each surface and Triple A-Mains will be run for each class on each surface.
** TRIPLE CROWN BONUS TRIPLE CROWN BONUS TRIPLE CROWN BONUS
-- If a driver takes FIRST in the Triple A-Mains on ALL THREE surfaces, then he will win a BONUS $1,000.00 !!!
-- This is PER CLASS - so a total of THREE Triple Crown Bonus payouts are up for grabs!
Dates/Times:
Friday, October 12, 2012: Test / Tune / Practice all day from 8:00am until Midnight.
Saturday, October 13, 2012: Qualifying Rounds and Lower Mains. Begins at 10:00am SHARP!
Sunday, October 14, 2012: Triple A-Mains on all three surfaces. Begins at 10:00am SHARP!
Entry Fees:
--$60.00 per class gets you a FULL weekend of racing! This includes practice Friday through the A-Mains on Sunday!
** -- MORE information on our website: www.MushroomBowl.com
Facebook page: http://www.facebook.com/pages/Mushro...y/279722488795
** Winnings are based upon a minimum of 30 entries per class and will be pro-rated below that mark. The Triple Crown Bonuses require a minimum of 20 entries within their class. All Prize monies mentioned consist of 75% "Hobby Bucks" MBRC Hobbies store credit and 25% cash payout.
Sounds awesome! Cant wait to here more!
Second Saturday in October would be great because I will be home on break!
THREE THOUSAND DOLLARS IN PRIZE MONEY!!!
x
I would be intrested in running 2wd mod and 4wd sc on the off road track only. I don't have any intrest in running on the other tracks. Is it possible to do that or do I have to run all 3?
This "Triple Crown" event is designed to test drivers' skills on three different surfaces. You are certainly welcome to run your trucks on the off-road track only, and you could win the prizes designated for just that surface, but you wouldn't be eligible to win any prizes from the other surfaces or the Triple Crown Bonus.
so am i adding this up correctly?...in order to win the $3000.00, you must win 27 A-mains? That sounds like alot of racing to fit into one weekend!
Well, yes... and no... To win ALL THREE Triple Crown Bonuses, you would have to win the A-Mains on ALL three surfaces in ALL THREE classes. There is a $1,000.00 Bonus for each class. If you win the A-Mains on all three surfaces in the class you entered, then you win the Bonus. If you enter in all three classes and win the A-Mains on all three surfaces for all three classes, then, yes, you would win a Bonus totaling $3,000.00.
It should be mentioned, that if you win the first two A-Mains on a particular surface for the class you entered, then you wouldn't be required to run the last of the three A-Mains on that surface / you have won that surface and you qualify that leg of the Bonus. With this said, you could potentially race in only 6 of the A-Mains (2 per surface) and still win the Bonus for the class (if you win the first two A-Mains on each surface).
And as far as a lot of racing going on, YES, you're right again! We plan to have test/tune/practice going on Friday, 10/12/12 and Qualifying Rounds and Lower Mains on Saturday, 10/13/12 and the A-Mains on Sunday, 10/14/12.
** I hope I didn't muddle the mix any more?
x
Details coming out tonight - check out the top of this thread for updates!
Details are updated at the top of this thread. Check it out !!!
I thought the grand opening weekend at "The Track" would interfere with the entries of this Triple Crown event, but the interest is POURING in! It looks like it's turning out to be a bit more filled up than I expected!
T-Shirt designs are completed and the trophies are ordered, the catering / food / beverages are in place, and we've got the buzz buzzing! :-)
