Go Back   R/C Tech Forums > General Forums > Racing Forum
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-08-2008, 10:05 AM   #31
Ray Murray's Avatar
Originally Posted by andyh View Post
Keeping the spirit of the class, scale realism, the final decisions on specs should be decided by each local track/organiser and should reflect the local flavor of the track/racers.
Cheers,
AndyH
hpiracing USA
Another point well taken!!!!!
Rather than putting in the time to come up with a national set of guidelines, each track/program should use their RCGT class to get new racers (and old retired racers....lol) back out to their respective tracks to have fun racing onroad again.
We can spend a lot of time going back and forth on specs, and what works for one track may not work for another. So for now, let's just kick around ideas on what works for your program.
Then, we can share this information here, so others can fine tune their RCGT program.
My focus has always been getting BRAND NEWracers out to actually "race", so PROMOTION at the LHS level will be the key to growth.
There is nothing like seeing a brand new racer on the track for the first time....PRICELESS!
Dee Lee is a nut and I don't condone what he will say next! (LOL)
WWSD....What Would Scooby Doo???
Ray Murray is offline   Reply With Quote
Old 10-08-2008, 06:51 PM   #32
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Another thing to point out that Andy brought up..
--HPI #4790 X-Pattern Radial Tire 26mm M-Compound (base spec tire)
--HPI #4495 X-Pattern Radial Belted Tire 26mm (belted tire, allows more speed)
--HPI #4490 X-Pattern Radial Belted Tire Pro Compound (belted and stickier compound for best performance)
These tires can be used as another option...all Xpattern. We have had much success with the M compounds, but this basically can make it so the larger tracks can use the belted tires and smaller run non belted. Again, when it is all decided upon. it will be all good.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
OC Circuit: http://socal.rcracing.com
CFX Paintworks:www.cfxpaintworks.com
Myspace.com/occircuit:http://www.myspace.com/occircuit
|RCGT|HPI|HOTBODIES|SPEEDPASSION|HITEC |PARMA|SPAZSTIX|IWATA|RPM|PENGUIN RC|
charlie_b is offline   Reply With Quote
Old 10-08-2008, 08:10 PM   #33
DJ919's Avatar
Yeah, without question to bring in new racers a track owner or organizer would have to keep it as simple as possible. Over-egineering on rules/specs and a bunch of rocket science talk definitely intimidates new guys and gals into not participating. I'm "kinda" noticing some other classes adding a little too much over-kill on the rules and specs to the point of the class not being attractive to new comers. 6 cells and a huge selection of qualified bodies, and a good tire compound selection are the big attractions that will hook new racers without a doubt. Not to mention the cool people that rep RCGT. The right formula is there
go to http://www.supergt.net to take a look at some of the cool full scale versions. Just click onto the Rounds on the left of the page and view the photo galleries.
http://dj919.blogspot.com
www.facebook.com/DJ919
RC Racing...It's the "hobby" that brings out the "sport" in you.
DJ919 is offline   Reply With Quote
Old 10-10-2008, 10:33 AM   #34
Ray Murray's Avatar
Ohhhh, Nice Link!!!!
Really nice looking rides in there....
Old 10-10-2008, 07:17 PM   #35
DJ919's Avatar
2009 just keeps looking better and better Ray. Got 4 new guys VERY much interested in racing RCGT next season. 2 have already ordered cars. Between Vintage TA and RCGT,,,Its going to be Bizzy
Finally able to give this report...Doing this from work.
Tested some RCGT set ups on Friday. Went out to the local park. Smooth asphalt/Black top surface. Tested with 3 different HPI bodies.
1. 200mm Mustang GTR
2. 200mm Camero SS (Modern body, not my slanted 6)
3. 190mm FD-RX7
Tires = HPI Xpattern - 1 set with foam inserts / 1 set without.
Motors = 27t / 19t brush ...I guess these could be compared to 17.5/ 10.5 BLs
I actually had to go back home to solder out and change motors...yeah I live that close to the park..1 mile..lol.
Ran 6 Cell 4600 NIMH packs.
I used cones to simulate different track patterns at different back straight lengths.
I was Focusing more on handling differences as far as aero and tires more so than that of actual speed.
Results...On the small track layout with the 27T The only difference came by way of the tires. The tires with the inserts delt with the sharper corners better due to lack of scrub. The Tires without the inserts seemed to give me more straight away punch and forward bite. I really couldn't feel or tell the difference in any areo involvement with the different bodies. All appeared to be quick.. Maybe a little more turn and straight away stabilization in the 190mm FD RX7 which has a extended front lip/defuser which helps with front downforce. The FD body also has small trench in the roof like that of the old Matt Francis Triple XT bodies. I never noticed that until today.
When it came to the Big track layouts with a much longer back straight, yeah, THIS is were the aero/and downforce came into play. I ran the 3 bodies with the 19t / 4600 NIMHs. By The Way This Go-Power Set Up Was FAST, and I believe its about as Fast as things need to be for RCGT on Larger tracks. Wouldn't recommend this go-power set up to new or inexperienced racers...On inserts, The 200 mm Mustang actually felt as if it wanted to lift. The mustang did this on the non insert tires as well. I put a couple of washers under the rear wing to boost it higher above the Mustang's roof, stayed with the insert tires, and the car stabled out and became a little more managable at higher speed. The 200mm Camero SS body Delt with the high speed REAL well without any adjustments. The 190mm FD RX7 Body was glued and stable as well, and did provide more initial high speed turn than the other two. No aero-push out of the turns. Maybe a little oversteer coming off the turns.
All bodies seem to work well. The Mustang calmed down after raising the rear spoiler a bit. The Camero SS was comfortable. I'd say the FD RX7 delt with both track layouts the best. Just some small testing, but every little bit helps ... I still think Driving styles and skills will be the final say so, no matter what body shell you run with. Yes, New or Inexperienced racers should definitely run everything on the Stock side of the fence.
Old 10-13-2008, 09:48 AM   #36
Super Moderator
charlie_b's Avatar
How about this suggestion....
Having RACE TEAMS with the same paintschemes...those who wanna have a race team race other race teams in RCGT USA. Kinda like a Le Mans 24 hour enduro? Make it a 2.4 hour Rc Enduro. Just throwing ideas out there.....
Old 10-13-2008, 10:14 AM   #37
DJ919's Avatar
I'm absolutely loving that idea Charlie B. That just puts even more fun into things. I participated in an oval enduro race way back when. Teams of 4. Till this day, I think that was the best race I've ever been involved in. A 2.4 hour enduro race? Now that would be a serious blast! Maybe a great idea for 09 HPI/RCGT challenges...The team deal sounds cool!
Old 10-14-2008, 07:42 AM   #38
TPhalen's Avatar
R/C Tech Charter Subscriber
SWEET! TEAM DRIVING!
I'd do this...cuz, you know, I have 10,000 cars and only use 6 of them...
RC Driver West Coast Editor
Look at my Horse
TPhalen is offline   Reply With Quote
Old 10-14-2008, 07:50 AM   #39
Ray Murray's Avatar
We did an endurance race once called the "FuNnY FoUR HouRs oF Raytona" and I can see a encore performance in 09....LOL
Old 10-14-2008, 10:07 AM   #40
anthony153's Avatar
Default Where?
Here in California, we have been running RCGT in four local tracks with much success as well as a couple of BIG trophy races since it's introduction at the beginning of the year. Because of it's low initial start up costs, it has become one of the most popular classes here in Southern Cal.
Could you list the four tracks?
anthony153 is offline   Reply With Quote
Old 10-14-2008, 11:20 AM   #41
Super Moderator
charlie_b's Avatar
Speedtech RC, San Gabriel, Ca
La Mirada Raceway, La Mirada, Ca
Ultimate Hobbies, Orange, Ca
Hobbytown Corona, Corona, Ca
Old 10-14-2008, 07:18 PM   #42
So when is this all going to happen ?? Team racing sounds like Fun !!!
M.B.
mb racer is online now   Reply With Quote
Old 10-14-2008, 11:42 PM   #43
DJ919's Avatar
LOL..."Four Hours Of Raytona"... I like that! Gotta put that on the 09 Agenda Ray
Old 10-15-2008, 04:27 AM   #44
k_bojar's Avatar
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
not too say that everyone one needs lipo and brushless...
but when that combo, you should be able to do a 4 hour race withouth issue well assuming, you have a couple of spare packs per driver
I've done a bunch of enduros in my day - from a single car per team (mini-z) to 4 drivers/4cars, and the oddest things ALWAYS happens
But they are fun as hell
Team Tekin | Bodies By Bean | Banzai Motors | ExoTek Racing | Team Belly
k_bojar is offline   Reply With Quote
Old 10-15-2008, 04:29 AM   #45
k_bojar's Avatar
and don't forgot about the soggy three hours of raytona the following year
ahhh the fun we had at the Alpine with Nitro cars
Forum Jump
Tamiya TB-03 gtypecanare Electric On-Road 1452 Today 08:57 PM
OC CIRCUIT v.2 Intelligentsia California Racing 8307 Yesterday 01:38 PM
The Speedtech RCGT Showdown Hebiki Racing Forum 1296 11-14-2009 04:42 PM
2009 Hobbytown USA St. Charles Racing thunderbt3 Wisconsin & Illinois Racing 916 10-07-2009 02:52 PM
Race for a Cause... A charity race with a twist! Hebiki Racing Forum 27 09-14-2009 08:42 AM
USVTA/RCGT Racing in New Jersey Ray Murray Racing Forum 275 09-07-2009 08:05 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
