clutch problems!!
clutch problems!!
I was just cleaning my GT when i noticed that the weels didn't spin well going forwards. They spun right backwards but not the other way. I took off the spur and thenspun them forwards and they went fine. so it is not in the transmission i know. I recall spilling a drop of after run oil in the clutch yesterday what should i do? thanks
Do you think the clutch is slipping? If you got after run oil in it, it might slip, but it will burn off the oil and should grab unless it wore out the clutch.
Does the truck have a slipper clutch?? Make sure its tight and clean. It could be that too.
Hope that helps
Hope that helps
You might want to post this in the offroad forum to get more responses.
I guess i will run it and see what happens. after it's done and the problem is still there i will take it apart and see.
thanks
thanks
Just remove the clutch bell. high chance it is just a bad bearing or a broken spring of one of the shoes.
crap!
No he still is puzzled ..lol
