How To - Post Full Size Pictures On RcTech
#16
When I copy/paste photobucket links I get a bunch of useless [URL] stuff on the links, some might run in to an error code so if you do you can just delete all the [URL] stuff leaving only the stuff between the [IMG] tags. Below is how my links look minus the -- at the beginning and end.
[--URL=http://s1188.photobucket.com/user/guys2nv/media/Ofna%20Hyper%209e/DSC_0041_zps00b68064.jpg.html][/URL--]
this is how it should look minus the * after the [IMG]
[IMG]*http://i132.photobucket.com/albums/q37/tksnobords/How%20To%20Post%20Full%20Size%20Pictures%20To%20Rc Tech/2014-03-19-13-12-51_zps01f4c55b.png[/IMG]
once you copy the photo bucket link...all you do is paste it into your thread...DO NOT click on this in the thread
#18
how to post pictures
I have window-7 and I can't figure out how to post pictures in the ale forum. Can any one help. When I go to attachment the drop down is blank.
#21
not working using FB... tried putting this url in the "Insert Image" button
https://www.facebook.com/photo.php?f...type=1&theater
but didn't work, any advice on why this didn't work?
#24
I clicked on your link... then clicked "view full size"... then right clicked on the image and copied the "image URL"... then pasted the image url into the "insert image" on my reply on rctech.
Basically, if you want to use the insert image button... the link you use must be a link to an image. So the link will usually end with an image extension such as .jpeg
#25
#29
